Question about Motorola Mobility RAZR V3
Unauthorized charger My motorola RAZR V3 phone won't charge at all. All it says unauthorized charger everytime i try it. I try with the phone on and i try with the phone off but it says the same thing. I try switching batteries but nothing. I try taking out the charger and putting it back in like 50 times but again the same thing happens. When i try with my car charger it just cuts off completely. And on top of that i can't get a signal at all nowhere. plz help me its frustrating
  • 2 more comments
  • jav1 Nov 13, 2007
    i have a Motorola cell phone charger and when i plug it in it says "unauthorized charger"...i have tried to put it in other Motorola chargers (car charger, new chargers)...how do i get it to charge???
  • lsdkfjklj Dec 06, 2007
    I got a Verizon v3c and it's doing the same thing. I think it needs a software update. But I can't even get my comp and the OEM motorola usb cable to recognize the phone. I have all the correct drivers and had it working fine before. Stopped working after the error showed up.
  • xiaoman Dec 12, 2007
    I have same problem.
  • Anonymous Dec 24, 2007
    I got that message on Sat and I did a master reset but it still wouldn't charge.
Posted on Dec 24, 2007
    Scholar:
  • 181 Answers
I software reset through the settings menu will usually resolve this, or a software update. Make sure you backup your data before doing this though, as you will lose all data in the phone.
If you are unable to do a software update, post a new question regarding this and I would be happy to help you out.
Posted on Dec 06, 2007
SOURCE:
Unauthorized charger v3
You should use Motorola Original chargers.
Mark
Motorola Support
Apr 15, 2014 | Motorola Mobility RAZR V3
Unable to charge
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Apr 08, 2010 | Motorola Mobility RAZR V3
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
Dec 22, 2008 | Motorola Mobility RAZR V3
Razr V3 won't power up anymore
try a new battery and also clean the charging port if after the battery and still nothing then you need to take the phone and have it tested.
Sep 10, 2008 | Motorola Mobility RAZR V3
Motorola razr wont charge
try to do a master reset/ have the mobile charger usb port service
Dec 29, 2007 | Motorola Mobility RAZR V3
Charging
Its the battery.
You can try putting the battery in the freezer for 8 hours, then leave it at room temperature for 24 to see if it can be saved.
Best of Luck.
Oct 13, 2007 | Motorola Mobility RAZR V3
Won't recgonize charger now
I'm not very sure about how the problem can be fixed, but the best thing to try is probably to make sure the charger is clean, and if it still doesn't work, try it on a different RAZR charger.
Jun 19, 2007 | Motorola Mobility RAZR V3
Motorola RAZR won't charge
that happens mostly with third party chargers..you may want to explore the option of charging your phone using the PC and a USB cable...you may be required to download a software or driver for it ..along with eh motorola phone tool
Apr 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
496 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
