Question about Canon PIXMA MP780 All-In-One InkJet Printer
Scanning problem Sometimes scanning fails completely, sometimes scanning begins but is not completed. There is no indication that scanning has failed, it just stops. The portion of the image that is scanned goes into memory (in use/memory light comes on) - only way to get rid of it is to switch power off MP780 and try again. At present time, unable to successfully complete a scan of anything. Help please.
  • Anonymous Sep 30, 2008
    the scaner is not connecting to my computer
  • 2,427 Answers
Here is the service manual for your printer
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
it has trouble shooting and step by step repair instructions
Posted on Dec 31, 2007
The car start, run ,and you can turn it off it take about 30min. Before it start back up.
Consider replacing the crankshaft positioning sensor. A crank sensor is an electronic device used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters.
The simplest and most obvious symptom of a failing crankshaft position sensor is the blinking "check engine" light in your car.
According to Do It Yourself.com "When the crankshaft position sensor begins to fail, the signal it transmits to the vehicle's computer begins to weaken. If left unattended, the signal will switch off completely. This, in turn, causes the car's spark plugs to die out, killing the engine. If you are having problems starting your car, it could indicate bad crankshaft position sensor".
Of course this may NOT be YOUR problem, but it sounds like it could be, doesn't it?
Feb 28, 2015 | 2000 Ford Contour
I can hear my Garmin 660 turn on and off but nothing shows on the sacreen
This indicates that the GPS is operating correctly in that you can hear sound but there is no picture on the screen. The display may be black (not lit) or white. Sometimes the image may be distorted with splotches or lines.
It's most likely, that your LCD display has failed. Sometimes the backlight has failed and the image will be very hard to see. If the LCD has failed completely then you may not see any image on the screen at all.
This is a very fixable problem. Replacing the display will resolve the problem.
Further troubleshooting tips can be found here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
An error occurs during installation
The CD Setup wizard will fail to complete the installation or sometimes fail to run at all because antivirus, anti-spyware or PC firewall is blocking the installation process.
To ensure a successful installation from the CD Setup Wizard, make sure all security tools are temporarily disabled before the installation begins. Enable back the antivirus, anti-spyware or software firewall once the installation is completed.
NOTE: If setup still fails to complete, check that you have selected the correct operating system in the setup options. You may also try restarting the computer and reinstalling from the CD if the setup fails to complete the first time. If all else fails, try searching for your device model at http://www.linksysbycisco.com/US/en/support/ and clicking on Get Downloads to download the latest firmware.
Nov 02, 2010 | Linksys WRT54G2 Wireless Router
Screen goes completely white. Sometimes during start up, sometimes while downloading. Sometimes just randomly.
That sounds like the screen is failing. If the display is white during the boot process than it is failing. You could replace the display but that is more costly than actually buying a new machine.
Mar 23, 2010 | Toshiba Satellite A75-S211 Notebook
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
WAsher not working
FL means 'failed to lock' the door didn't lock, so it didn't complete the cycle. Sometimes it's just because the door didn't shut completely or you may have a bad door latch assembly, or worse case, a bad control board. First try unplugging it for 5 minutes, then try starting another load making sure the door is closed completely, if that doesn't help you'll need to open it up to test the door latch.
Jul 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
HP CM1015 copy/scan problem
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
Jan 17, 2008 | HP LaserJet CM1015 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
126 people viewed this question
Clive
Clive
old marine
old marine
