Question about HP PSC 1350 All-In-One Thermal Printer
HP PSC1350 All-In-One Printer
When I am printing pictures, the printer will print in spurts, starting and stopping for a few moments, then starting again, over and over until it eventually prints everything. It can take 30 minutes to print 8 pages.
  • Bill M Aug 24, 2007
    Thank you, guest, for finding the answer to my printer problem. Sometimes it is fast and sometimes it is slow. I guess I had loaded too many pictures into it for printing. Thanks again!
  • jvtpearce Jan 08, 2009
    printer will advance paper then stops. after 30 minutes or more the printer will finally starts the printing job then stops then starts again and so on and so on until the printing is complete. what is up?
This printer prints at a really slow 1.4 PPM, and if it's doing that, it means that the buffer in the printer is full and it must print what it has in memory before recieving more of the page, if it's a really high resolution picture, it can take forever to print. This isn't a defect at all, it's just something that you can't fix that makes this printer useless for an office. I have this printer too, I usually just go do something while it does its thing...
Posted on Aug 24, 2007
SOURCE:
How can I stop my hp deskjet 960c from printing unwanted pages once it has started printing?
Turn the printer off and unplug the printer cable from both ends (printer and computer ) and cancel the documents from the printer list.
Sep 25, 2009 | HP DeskJet 960c InkJet Printer
My computer stopped recognizing my hp psc1350 and it won't print
If this is not hardware problem then most probably the driver is corrupt.
First uninstall the printer completely using the procedure below (taken from HP website).
Uninstalling the software
Use the following steps to uninstall the software:
1.Disconnect the USB or parallel cable from the all-in-one.
2.Click Start , click Programs (click All Programs in Windows XP), click HP , select the all-in-one product folder, and then click Uninstall . Follow the directions that appear.
The basic device drivers have been removed after completing this step. If you were having problems with connectivity or the basic print or scan drivers, you may reconnect the all-in-one at this point to reinstall it. If the problem is not corrected or if you had other problems, continue to the next step.
3.Open the Windows Control Panel by following these steps:
* Windows 98, Me and 2000: Click Start , click Settings , and then click Control Panel .
* Windows XP: Click Start and then click Control Panel .
4.Click Add/Remove software (click Add or Remove Software in Windows XP).
5.In the list of installed programs, locate and select HP Photo and Imaging 3.0 or HP Image Zone , and then click Remove . Restart the computer after uninstalling if prompted.
6.In the list of installed programs, locate and select HP Software Update , and then click Remove .
7.In the list of installed programs, locate and select Memories Disk Creator 2.0 , and then click Remove .
Reinstall using updated drivers from the link (for XP)
ftp://ftp.hp.com/pub/softlib/software4/COL8901/mp-23606-2/gc_w01_ENU.exe
If windows vista then it will install the drivers automatically on connecting the printer
Jul 28, 2009 | HP Office Equipment & Supplies
HP PSC 1350 not printing magenta
try a reset on the printer.see if it works,if not its time to get it serviced.
May 25, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer won't print and resume light keeps flashing
I went through the HP troubleshooting and it started printing OK when I Stopped and Started the Print Spooling under Administration Services:
-START
-Control Panel
-Administrative Tools
-Services
-Scroll Down & Right Click on Print Spooler, Choose STOP, then OK (if needed)
-Right Click again, choose START, then OK (If needed)
After a few moments, it started right up for me and the Test Page I had in the que.
Hope this helps someone.
Mar 20, 2009 | HP Deskjet D4160 InkJet Photo Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP1500 Alignment Test page keeps printing
I just had the same problem on a PSC1350 after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Dec 10, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
HP PSC 1350 All-In-One Thermal Printer Logo
167 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
