Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Yellow tint to my panasonic PT-50LC13 screen
My LCD projection TV is approx 3 years old. I Suddenly noticed that white or very light colors turn bright yellow. If I turn down the "picture" (which is the contrast i think) the yellow starts to disappear and is totally gone when the contrast setting is at about half. This causes me to lose most of the quality from the TV. I have replaced the lamp once and keep hearing nightmare stories about this model. If it's an expensive fix, I might consider buying a plasma.... any ideas?
SOURCE:
  • 59 Answers
SOURCE: Sound problems on PT 50LC13
try unpluging and plug back in, same on cable box if you have one i have had calls with no sound and found cable box is the problem just unplug for about 30 sec and plug back in
Posted on Oct 23, 2007
SOURCE: panasonic pt-50lc13 shutting off
The Lamp is burnt out, Replace.
Posted on Dec 26, 2007
  • 579 Answers
SOURCE: Panasonic PT-53wx42 has a greenish/yellow tint to it.
Trty re-soldering the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Posted on Jan 02, 2008
ladywinn
  • 5138 Answers
SOURCE: panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Posted on Feb 05, 2008
jomabug76
  • 1148 Answers
SOURCE: Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Posted on May 15, 2009
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Yellow tint picture is yellow in middle
That indicates your color wheel or optical block is bad. Repairs are usually pretty costly. Around 1100 to 1300 dollars. Hope this helps.
May 31, 2011 | Panasonic PT-50LC13 50" Rear Projection...
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a panasonic rear projection lcd, it has a yellow tint around center of screen. Help
My PT-43LC14 has a yellow tint on 3/4 of the bottom to top. the top 1/4 seems normal. I removed the bulb assembly and it looks OK. Any ideas. Is there anything I can doe myself. and if so what is the p/n I can buy?
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
LCD tv power light doesnot come on.
These off brand almost always have power supply issues that have to be troublshot. $150 at a local tv repair.
Nov 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Oct 07, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
