Question about Samsung HCL4715W 47" Rear Projection Television
See lines in HD cable or DVD source images, also maybe a problem w/ color, see extra blue haze
Model: HCL4715W Service Model: HCL4715WX / XAA Ok, I don't know what I'm talking about here. TV was fine earlier today, then suddenly the cable image looked funny, could see lines in the screen was the first thing I noticed. I figured my daughter accidentally hit the 'zoom' image or something, and didn't have time to look at it. Now, coming back home, and looking at it again, not only is there lines in the screen, but the picture is a bit hazy w/ extra blue being seen as a shadow to the main images. Checked the cables, ran a DVD and had similar problems, so it's not the cable box, or the cables. I've seen this kind of problem before, at least w/ the color, only to realize in sliding the tv around one of the 3 component color cords was coming loose, pugged it back in and it fixed problem in the past... but that's not the case now... I recently re-wired everything adding a receiver, but was still sending the video images via component cables in each case from the DVD and the HD Cable box directly into the TV, so I can play music on the receiver while still watching TV, so it's not a problem w/ the receiver. I tried the perfect focus, but that didn't do anything. I looked at the convergence thing, but don't really know what to do with it. The TV is almost 5 yrs old, maybe I have a bad bulb or something? Any troubleshooting tips to try to narrow it down, and hopefully fix it cheap myself???? Thanks, Karz
  • 1 more comment
  • zearles Nov 30, 2007
    I have a Similar Problem. All of my colors are off and there is a white line across the top. We believe it is the convergance chips but we aren't 100% sure. Anyone have any ideas?
  • karz10 Dec 30, 2007
    No help on this yet eh?
    Still have the issue... I don't think it's the convergence issue for me, I have seen the convergence problems w/ pics on other forums, and they have bowed lines in their red/green/blue and multi layer images, I don't have that problem.
    I just have lighter images ghosting to the right over darker images and a loss of resolution (like maybe line doubler isn't working anymore?)
    Any one have any ideas? Or is this just a ploy to pay for some upgraded service w/ unknown results?
    Thanks,
    Karz
  • karz10 Feb 23, 2008
    Well, I didn't want to spend $400+, even $300+ on such an old TV, if there was any way possible to avoid it. Considering it's only a 47" rear projection, I would rather have a similar sized plasma, or a bigger DLP RP, for a little more money. But that's just me. I found another thread where a guy had the same blueish shadows and did fix it when replacing the whole convergence board bought on partstore.com for $85, so I took the plunge and bought it, and swapped it out. I'm about 85%-90% to new condition now.
    Only reason I'm not 100% is coz it seems my whites still *glow* a little more than they once did. The blue shadows are gone, and the resolution is back to 100% HD now, which is great, I just think the whites/light colors glow outside their lines a little bit. Since the tv's image was so messed up for so long, prior to finding the fix, I can't tell anymore if it was like that before, or when the other problems came up, this also happened, or if the new board is actually causing a new problem, but I guess I have no way to no for sure, and not much recourse if it was, at this point.
    If money was no object and I loved this tv, I'd pay to have it fixed. But since I'm not in love with it long term, it was worth $85 for the part and some of my time to fix it close to 90%.
    Karz
  • 927 Answers
It sounds like convergence problem to me. There are two ways to correct these concerns; Samsung does sell boards, so if you are handy you can replace the boards yourself. BUT I recommend calling a factory authorized service company. It isn't costly, the cost will run around $400 -$550.
Posted on Feb 23, 2008
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
Sony rear projection LCD pink haze/blue line
Optic engine. No doubt. Those encroaching lines are just going to get bigger and more annoying with every day.
Check with Sony to see if your set still falls under the natural or extended manufacturer's warrantly. Most optic blocks are warrantied for 2 years (3 years or more on some models).
Post your model # and we can tell you if it is covered by the manufacturer.
Jul 03, 2009 | Acer AL2671W 26 in. LCD Television
Connecting panasonic dvd to olevia tv
when connecting a dvd player you want to try using the yellow red and white cables.. ( AV CABLES) to the television.. just match the same color on the back of the television. Once that is done change the source on your remote until it displays composite then the image should be on.
if you will like a better image quality use the component cables (green, red and blue cables) but the dvd player has to have does colors as well or else it wont work.
Mar 21, 2009 | Panasonic DVD-RV30 DVD Player
LCDTV - Picture problem
Do the lines only appear on the Cable box input? It maybe be a problem with your cable. Try to isolate the problem.
Do you see the lines on all sources such as your DVD player as well? If you press the MENU button on the Sharp remote, do the lines go through the menu as well? If yes, it is most likely a TV problem.
A bunch of lines sounds like it is most likely a problem with the connection with the LVDS cable, if not that, then a defective main board.
There isn't really much you can do about it now.
Since the TV is less than a year old, I suggest calling Sharp to locate a local authorized service center.
Mar 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Loss Of Blue Color
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Feb 25, 2007 | Toshiba 57H84 57" Rear Projection...
Similar Problem with Verticle Lines
sounds like a loose cable inside the set, if not it looks like a logic main board
Sep 04, 2006 | Samsung LTN1535 15 in. HD-Ready LCD...
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Samsung HCL4715W 47" Rear Projection Television Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
