My camera flashes E:91:01 and the flash has recently stopped working. The flash icon flashes continuously with the E:91:01 but you cannot change the flash settings at all, the up button is inactive. I've turned it on and off, the battery is fine.. Where can I go to get it fixed? Thank you!
-   in my DSC W35 flash icon is flashing & E91:01 message also, @ this movement flash stops working.
-   Guest
Jul 05, 2008
-   My camera flashes E:91:01 and the flash has recently stopped working. The flash icon flashes continuously with the E:91:01 but you cannot change the flash settings at all, the up button is inactive. I've turned it on and off, the battery is fine.. Where can I go to get it fixed? Thank you-   vickyshiro
Jan 22, 2008
-   Can this problem is solve? My camera is blinking flash logo and E:91:01. And what kind of workshop should repaired? And where can I buy a flash set and it price. Please answer the question.
This E:91:01 indicate that the camera flash function is faulty.you need to replace the faulty flash unit. to get away the E:91:01 flashes on screen , what you can do is to do a factory reset follow by turning off the flash function.the screen will not show the E:91:01 and you can use the camera without flash function.hope it help.
SONY DSC-W55 flash error E:91:01
well i had the same problem, and i tryed everything, even opening the camera and see if any visible damage on any part (nothing), so when i try initializing again ( menu>setup>option #1), right after the "ok" over new reseated date, i went to the flash button and turn it off, and at least the annoying flashing error is not there - that means it is software error, because all flash functions work till it detects that has an error wile charging/loading the flash.
Hope it helps. TENFERRE
