Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
My Keurig B60 is Suddenly Brewing WEAK Coffee
By hkfox on Mar 18, 2009
My Keurig K-Cup machine has been making nice strong cups of coffee for over 8 months, which was great. I loved it. Now suddenly it has started to brew super weak coffee. (Barely tinged with the coffee color/flavor---not even drinkable!) I am using the same brand of K-cups that I have always used (Gloria Jean).
I have already descaled it & still the problem persists.
Help! I miss my Gloria Jean coffee!
Solution #1
posted on Apr 01, 2009
Somewhat Helpful)
ginko
Rank: Guru
Rating: 89%, 5261 votes
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
Keurig says ready to brew but when we press the brew button nothing happens
Answer
It is not brewing. It turns on, sounds like it is going to brew and then cuts off.
Answer
my keurig is not brewing once cup size is selected. it says "brewing" but nothing is...
Answer
It will not stay on. I turn it on, it makes a loud whirring noise for 2-3 minutes, and then shuts... (More)
Describe your Coffee and Espresso... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , PA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
