Question about Kenmore 57029 Side by Side Refrigerator
Kenmore ice maker
I have a kenmore refrigerator and the ice maker just stopped working. It is an older one with the ice maker in the actual freezer (not in the door like the newer ones). I checked the water and it is flowing into the fridge, but no ice. I touched the bottom of the ice maker and burnt myself (blistered) - extremely hot. I just unplugged the fridge and then disconnected the electrical connection from the fridge to the ice maker. Any ideas what would cause this? Should I just replace it?
  • Anonymous Mar 13, 2014
    good water flow in door but still no ice ,I lowered the freezer temp to 4 degrees a couple of weeks ago it started the make smaller ice cubes then it stopped altogether. .Q-1- how to lower the shutoff arm for it to make ice or does it matter?
    Q-2- will unplugging the fridge overnite for 8 to 12hours recycle the system?
    Q-3- if none of the above work guess will buy bagged ice again...
  • Anonymous Mar 28, 2014
    Checked ice maker, doesn't seem to be a problem
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
6ya staff
SOURCE:
The ice maker on my Kenmore refrigerator has stopped working . Please help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Nov 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice maker not working
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker not working on kenmore top moun t freezer
Suddenly my icemaker stopped making ice. I have a Kenmore ref. with a top freezer.
May 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Ice maker stopped working
try manualy adding some worm water into the cuber . once the cubes refreez see if the yacualy get ejected. the ejection proces is activated when the ice maker reaches aprox -5f enshure the freezer is atual reaching these low temps as well .
Oct 20, 2008 | Kenmore Refrigerators
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 57029 Side by Side Refrigerator Logo
492 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
