Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Frigerdaire Dishwasher My dishwasher will not start. I check the breaker...how can I tell if a fuse is out on the dishwasher
  • 6 more comments
  • Anonymous Jan 05, 2008
    the panel lights up but it will not do anything.
  • meme11 Jan 14, 2008
    1500 series
  • robandmel505 Mar 03, 2008
    I have the same problem. The unit is only 2 months old. All lights work but the unit does nothing
  • Anonymous Mar 19, 2008
    CYCLE/OPTION LIGHTS COME ON BUT WHEN YOU PUSH START THEY CYCLE/OPTION LIGHTS START BLINKING AND THE DISHWASHER DOES NOT START?
  • beccailene Apr 22, 2008
    I have the same problem. All the lights work, but when I press start the washing light just blinks. I got it to run a few times after this first happened by pouring a glass of water in the bottom of the dishwasher to prime it. I thought that was the problem but it is doing it again and a glass of water is not helping.
  • Anonymous Oct 18, 2008
    soap
  • jgreengiant Nov 29, 2008
    I have the same problem. When i press the wash, heat dry, and rinse buttons the lights work for them but the washing light starts flashing and none of the features work.......
  • misschotan Mar 30, 2009
    The dishwasher is new. I've used it three or four times and now it won't turn on; no lights, no sounds - it's almost as if it's not getting power. We checked the breaker but that wasn't the problem. Could it still be the door switches? how do we clean and put them back?
  • 413 Answers
A blinking light, and possibly no lights, with the door closed may indicate faulty door switches (very common). Depending on the model, the switches can be removed, cleaned and put back
Posted on May 29, 2008
Hager fuse box
by fuse box I assume you mean breaker panel. sometimes when a breaker goes bad, it can trip and you wont be able to tell until you go to reset it. if you are positive the dishwasher is getting power, then check the back of the dishwasher where the wires going in. there is probably a terminal block where the wires are connected. check there with a multi meter. be careful. use rubber gloves if you are going to do it.
Jan 05, 2014 | Electrical Supplies
Dishwasher won't start
1) TEST some fuse blown +c. breaker trip , reset.
2) Test the outlet wall, and reset the c.breaker house.
3) Test the switch door, if there are defective or open the starting relais will not start the main motor see the schematic.
May 10, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Start won't work.
Thank you for contacting fixya.com.
A check should be made with the volt/ohmmeter to check if voltage is available to the dishwasher wiring. A voltage check is made by setting the volt/ohmmeter on the 150 A/C scale and placing one probe of the volt/ohmmeter on one wire that supplies voltage to the dishwasher. Place the other probe on the remaining wire. The meter should read 110-125 volts. This would indicate that electrical power was available from the circuit breaker panel to the dishwasher terminal box. If there is no voltage at the dishwasher terminal box electrical wires, the problem could be a defective circuit breaker or fuse, house wiring burned or broken from circuit breaker panel to terminal box. If a defective circuit breaker or fuse is suspected, it would be recommended that a qualified electrician perform these repairs.
Please check this links for an in-depth knowledge to troubleshoot your problem:-
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help
http://www.acmehowto.com/howto/appliance/dishwasher/diagnose-dishwasher.php
http://www.partselect.com/dishwasher+dishwasher-wont-work+repair.htm
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm
Please get back to us if you have further query else please accept the suggestion.
Jun 27, 2011 | Dishwashers
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
The dishwasher wont turn on. I'm not sure if is fused or not. How can I fix it?
Many dishwashers, due to their power consumption, are on their own house circuit. It may have blown the house fuse or circuit breaker. Ours does it about once every 6 months or so. I just reset the circuit breaker. I'm sure an electrician would tell me to replace the dishwasher or have it serviced to determine why it periodically blows the circuit, so if it has blown the circuit breaker, you should determine why before running it again (unlike me!).
Nov 07, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
Fuse for dishwasher
I am not aware of any fuses located in the dishwasher. If your dishwasher is has no power coming to it check your house breaker.
Jun 07, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My GE dishwasher, when i push the start button nothing happens.
1)check any fuse had gone in electronic board.
2)check the input voltage to pcb.(normal)
Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Dishwasher has no power
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
334 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
