SOURCE: hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
SOURCE: Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
Hello, I have a Vizio 42 in screen in perfect condition if anyone is still interested. The back lights went out in the TV and I decide I wanted a bigger one anyways. I am will to sell very cheap and have already removed it from the TV as I was getting ready to list it on eBay. The parts are already listed. It's a Vizio 42 in VW42L HDTV10A. Anyone interested e-mail me at [email protected] I will ship via UPS as well.
Thanks,
Andrew
