FixYa.com
Tags:
Toshiba DKT 3010 Corded Phone
Resetting company voicemail
posted by cdiddy on Aug 14, 2007
How do I reset my company voicemail
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by tech555, posted on Mar 29, 2008
What do you mean by reset your company voicemail? Passwords, names in mailboxes, changing greetings either personal or company, if you can provide me with some additional information I can help you.
Best Solution
posted on Aug 14, 2007
Helpful (85)
Priority1
Rank:Wiz Wiz
Rating: 84%, 256 votes
First, there are two things you need to know. The DKT3010 phone will work on different Toshiba phone systems AND you can have different voice mail systems. The phone system and voice mail are separate to some extent. You need to know the model of the Toshiba main control unit and it would help to know for sure which voice mail system you have.
You SHOULD have an administrator's guide for the system and voice mail or someone at the office in control of making simple changes to the system... however, depending on the company that originally installed the system you may have gotten nothing (hopefully they are still in business and you know who they are!!) Most of these systems can be programmed over the phone quickly by the company that originally installed it. There are probably passwords that you would need to know to change any programming features and if you don't know what they are you would be out of luck.
Your best bet is to find the company that installed the system. There may even be a sticker on the main control unit with their contact info. Next I would try to find a local installation company that could help you get the changes made and set you up with a way to make future simple changes yourself. Get ALL the information needed to make any changes like passwords etc.. even if you do not want to do it yourself, you NEED to have this information in case the company goes out of business!
Comment by Priority1, posted on Oct 05, 2007
I write up a huge reply explaining your situation and how to go about solving your problem but I get a "not-helpful" feedback. Thanks!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Phones problems?
Toshiba DKT 3010 Corded Phone (dkt3010s)
Redial for 10 digit dialing
Our province has gone to 10... Answer This...
Toshiba DKT3220
I get a busy signal when I try... Answer This...
Lines are lit.
two of the three phone lines... Answer This...
1 EXT.VOICEMAIL REST
Toshiba DKT MODEL DP5132-SD Answer This...
Fix encoding on Toshiba Strata...
We have about 5 new Toshiba... Answer This...
Repair Service
Find Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
