Compaq Presario 5070  PC Desktop
Problem for Compaq Presario 5070 (117815-004) PC Desktop
Cant perform a quick restore.
By howard571 on Aug 14, 2007
I have an older Compaq Presario 5070 desktop and I'm running Windows 98.
I go to the quick restore page and pressed full restore and typical restore and my computer does nothing. I've run into this problem before and only solved the problem after weeks of trying over and over again!
I even tried reinstalling Windows 98 a couple of times. The reason I'm even trying to perform this operation is to debug my system and start fresh. I'm trying to avoid costly repairs if I can.
It was suggested that there may be files missing.
HELP!!!
Solution #1
posted on Aug 14, 2007
Not Rated)
warewolf2001
Rank: Wiz
Rating: 82%, 121 votes
what size is yous hard drive and is the windows installing it'self properly and the other problem is have you got all the motherboard drivers if not then the system will become unstable and the hard drive will need to be format back to manufactures default as the files thet were on drive are burrired deep and the only way to get rid of problems is using a program called kill disk then using your win 98 start-up floppy and fdisk the hard drive then partition then format the hard drive then install windows on then all other files for motherboard and graphics and other devices.
it should take you about 1 day to get back on line with pc up and running.
hope this helps
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario 5070 PC
Questions and Unsolved Problems for Compaq Presario 5070 PC
Do you recommend Compaq Presario 5070 (117815-004) PC Desktop?
Answer
Answer
connecting altec lansing speakers. 221 amplified speaker system . trying to connect to my compuer.
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
adr=610c Abort program code error 6193
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Presario 5070 PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
