Question about Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive
Toshiba satellite monitor problems
The monitor no longer responds. It remains black. This was after switching from an external monitor back to the internal monitor. I removed the extra memory module and hard drive. When these pieces were placed into another laptop, the hard drive functions fine, however the extra memory module causes the screen to go black, there too. I tried to replace the hard drive in the old toshiba, but the screen still remains blank. Any and all advice would greatly be appreciated.
    Problem Solver:
  • 51 Answers
Sounds like the memory module is bad. Return it or get a warranty replacement.
Posted on Aug 17, 2007
Toshiba satellite p105-s6227 built in and external monitors not responding
Your Graphics Adapter may be bad. You didn't post the results of the screen testing in another laptop? Did the screen work? Has the laptop been overheating due to dust build up in the fan, vents, heatsink? Has the Thermal Paste degraded/overheating causing a failure of the Graphics Adapter? When you boot does the HDD blink? Sound? Fan spins? Just no monitor? Any damage? drop? Possible loose connection of the Graphics?
Apr 08, 2013 | Toshiba Satellite P105-S6227 Notebook
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
I need to install external monitor on my toshiba. help
You can switch to anexternal monitor by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the external monitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Toshiba = Fn + F5
Aug 10, 2011 | Toshiba Satellite M55-S325 Notebook
I have a Toshiba Satellite M45 and the monitor no longer works. there are some lines on the screen (left) and the rest of the screen is black.
Can you tell us please, what - recently - happen to the lap? have it been shocked, dropped down ,,, ?
To test, u can plug external monitor in the VGA-port, turn ON the laptop, after a minute, toggle the display once, or twice, or 3 times to change the display path to the external monitor.
Tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite M45-S2652 Notebook
Laptop Monitor Problem - I have a Toshiba Satellite Laptop. I had a system crash and I think I may have had a second problem with my monitor on my laptop showing, it went black and flickers on and off. ...
Possible disconnect of the wiring harness from the LCD to the motherboard? Might just need a new screen, but always check the simplest first. Flickering may imply faulty wiring or a lose connection in my opinion.
Mar 02, 2011 | Toshiba Satellite A135-S4467 Notebook
My toshiba satellite has a wide colored band showing. I can adjust the monitor back and forth and most of it goes away.. any solutions ?
HI there,
A soon as you can, connect the laptop to an external monitor and switch to that monitor when connected by holding down the "fn" key and pressing F5. If the external monitor displays normally with no colored band, then your laptop's screen needs to be replaced.
If the same colored band appears on the external monitor, it means that your video chip/controller on the motherboard is about to fail, at which point the screen will go black and stay that way. In this scenario, you need to have the chip on the motherboard replaced or the motherboard itself.
Here's hoping your laptop is under warranty still. If it's not, go to eBay and type "Toshiba Laptop Motherboard Repair" in the search window. Hopefully, you can get a flat rate there of $125 to $175 for the repair.
Best of luck to you.
Aug 28, 2010 | Toshiba Satellite A135-S4467 Notebook
Screen will not come on.
If the Toshiba appears to boot up but the screen is black then it could be a back-light problem. For instruction to determine the fault and fix please follow my instructions - click on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 24, 2009 | Toshiba Satellite P105-S6104 Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Moitor extremely dim; how do I get the external monitor to start
Ok friend this equipment unlike the rest has a card of video piggy back that is inserted in the system board, according to the symptoms of the fault that you describe, this one resides in the card of video which you must replace to be able to solve your problem. Good luck.
Dec 16, 2008 | Toshiba Satellite 5005-S504 Notebook
Random screen freeze
You are going to need your WINDOWS CD: http://www.updatexp.com/scannow-sfc.html
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite Satellite 5200 Series 15 SXGA LCD Display-LQ150F1LH16-P000353350 CD-ROM Drive Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
