I just purchased the Samsung HT-A100 Home Cinema system, but I have two problems: I can only listen to a cd when the television (Samsung LE-40A656) is switched on and my two samsung remote controls work on both my television as my cinema system, so when I want to turn off my cinema system, it turns of my tv!
Does anybody know if this is "normal"..?
Thanks!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
SOURCE: i cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
SOURCE: Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
I have the same problem with my HT-715T system!
