Question about Goldstar WG5200ER Air Conditioner
GOLDSTAR BG5200ER I HAVE MY AIR CONDITIONER IN THE WINDOW IN MY BACK ROOM. I TURN ON AND I NEED WAIT FOR THE AIR COOL. IS TOO SLOW. MAY BE SOMETHING IS BROKEN OR IS NORMAL COOLING CAPACITY IS 5200
  • 50 Answers
Measure the temp of the air blowing out. It should be 20 degrees lower than the intake air at the filter. If not, we need to dig deeper.
Posted on Aug 18, 2007
SOURCE:
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Kenmore window air conditioner model 580. Blows air but nott cool air. wont cool the room.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 02, 2011 | Kenmore 76129 Air Conditioner
I connected my brand new one Danby DPAC 7099 unit, but is not cooling the room. It only goes to 1 degree less than the actual temperature of the room and stays there forever. Is there something I should...
Your question "Should I wait before starting the unit, after bringing it from the store?" may be the answer to the problem. If the unit was turned on it's side or back when you brought it home in your car? Then yes. that is the problem. When AC Units, Dehumidifiers, etc are turned on their side or back, the refrigerant gas and the lubricating oil runs out of the compressor. It should not be operated, unit it's been setting upright for 6 to 8 hours. This allows all the fluids to run back into place.
If the above is the case. Turn the unit Off and unplug it for at least 6 hours. Hopefully, all the fluids will return to where they are supposed to be.
I hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | Danby DPAC7099 Air Conditioner
My through the wall whirlpool air conditioner has water sprinkling through where the cold air comes into the room is my air conditioner broken??
No... either the drain hole is plugged or the unit is tipped forward instead of backward...make sure that the unit outside the window is lower then the inside by just a bit... The drain holes are usually in the back outside corners and often they plug up with dirt or debris...
heatman101
Jul 12, 2011 | Whirlpool Designer ACU109PR...
I want to make the air cond. get cooler. I want to cool fruit in this room. Can it be done. Maybe override the therm.?
To cool fruit ect you need something much more than a window unit air conditioner, they just don't have the cooling capacity to do that job. You need a walk in cooler to cool food down.
Jun 19, 2011 | Maytag M6Q10F2A Air Conditioner
My air conditiner does not want to turn on.
heatman101
May 31, 2011 | LG Goldstar GWHD5000 wall/window Air...
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
Room does not cool down
It may be low on freon or have a leak, I'm not sure if that particular unit has Service Ports on it to enable a recharge, consult your Owner's Manual for any Troubleshooting Tips. www.goldstar.com
Jun 05, 2010 | Goldstar KG6000R Window Air Conditioner
Goldstar WG5200ER Air Conditioner Logo
128 people viewed this question
Top Goldstar Heating & Cooling Experts
Sumeet Sodhi
Bill Long
mark gardner
mark gardner
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
