Home | Minolta | EP4000/5000 CS/PRO Copier | Copier ricoh aficio 450...
Minolta EP4000/5000 CS/PRO Copier
Problem for Minolta EP4000/5000 CS/PRO Copier
Copier ricoh aficio 450 error code SC 542-00 ?
By kristanzania on Mar 18, 2009
could you save this problem ?
Solution #1
posted on Mar 18, 2009
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 568 votes
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    The fusing temperature does not reach the fusing standby temperature within
    125 seconds after the main power switch is turned on.
    - Possible causes -·
    Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · BICU defective
    · Power supply board defective
    · Poor fusing unit connection
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Comments:
Mar 18, 2009
- hope this helps pls do let me know
Was this helpful?
Yes
No
Popular Solutions for Minolta EP4000/5000 CS/PRO
Questions and Unsolved Problems for Minolta EP4000/5000 CS/PRO
Do you recommend Minolta EP4000/5000 CS/PRO Copier?
Answer
Answer
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have... (More)
Answer
How do I take a meter reading on a Canon IR2270? Alan
Answer
my coier is producing a very dark page. completely black . It also have a tedancy of blinking the... (More)
Answer
I am using Konica Minolta C353. some messages showning in display. ''Malfunction Detected'' Error... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Minolta EP4000/5000 CS/PRO...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
