Copiers
Problem for Copiers
Generic problem for all Copiers
Our Gestetner DSm645 gives Dark Cop...
By dwani_heron on Mar 18, 2009
The Copies Come out with Streaks and Dark Spots.
At times the copies come out almost fine but still Dark.
I wonder if the toner is leaking out inside or if the drum
has some Latent imagery.
Thx for any help or input.
D Heron
Solution #1
posted on Mar 18, 2009
Not Rated)
sandmanmac
Rank: Wiz
Rating: 84%, 800 votes
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
mesin menyala tapi tidak kuat bekerja,kemudian layar touch screen mati
Answer
Canon calculator repair. MP25DV will not add numbers.
Answer
I have black strip running top to bottom of copy. Machine has 65,520 copies on the counter
Answer
is it safe the radiation of sharp ar-m35ou+
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , CA
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
