Question about Canon BubbleJet i560 InkJet Printer
Paper jam or something?
All of a sudden, my printer seems to refuse to feed paper through. One side will try to feed, but it jums wont go through the other side.
    Sergeant:
  • 390 Answers
Yes, you definitely have a tiny jam, paper or other (you would be suprised what can end up down the back of a printer!!!) Get a torch, and a pair of tweezers and play find the little jam...it may be really small and hard to get out, hence the tweezers. I am willing to bet you fins a jam. When it is out, reset the printer by turning it off and on again. Unplugging it while it is off and replugging it before you turn it on again will help too.
Posted on Aug 31, 2007
SOURCE:
Paper jam
Dear Sir,
By analyzing your printer paper jam problem,it deffinately due to paper piece or dust particle wrapped to the the printer page roller.So check your printer keenly for any paper piece or any other obstacle disturbing printer roller and clean dust wrapped on printer roller with brush.Then turn on the printer give the page to the printer,care must be taken that page inserted is must be straight.then give the print. It definitely solves your problem.if you have any problem regarding this issue comment your problem with more information,we will glad to assist you.
good luck
thanking you for choosing fixya
Aug 26, 2009 | Canon PIXMA iP1200 Photo Printer
Paper jam in printer
Dear
It is the problem paper end sensor is open or fedd sensor is open.
power on then paper jum it is the same problem. or power on printer is ready after print command then paper jum it problem your cartridge chip is diable or feed claught is not active
Jun 17, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
PRINTER FEED ISSUE
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
Paper fed
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Printer wont feed paper on one side
This may sound strange, but it works more often than not. Try unplugging it, turning it upside down and shaking it vigorously. Also, take some canned air and spray into where it feeds the paper. Just be careful not to spray into the ink-head.
Mar 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper jam
it maybe one of the feed wheels are jammed, if you can get it apart then have a look at the gears and wheels, there maybe something jamming the wheel itself.
Feb 11, 2008 | Canon PIXMA iP1800 Printer
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Canon BubbleJet i560 InkJet Printer Logo
91 people viewed this question
Clive
Clive
old marine
old marine
Ekse
