Hi I have now tested the level switch as it was running by blowing into it. It definately switching. Any other ideas?
Comments:
Aug 13, 2007
- When i turn on the dishwasher the pump starts empties the excess water, but then carries on. No water enters the dishwasher at all. I have checked the pipes etc and i think the first soleniod valve my be damaged. Could i be right? On the valve is 240vac on both sides but no water after the valve.
Aug 14, 2007
- Hi Ive checked the valve, seems clean and there is 3.6Kohms on a resistive test, seems not to be this. I wounder if it is that pressure switch you spock of. I did force it by blowing into it but i wounder if the sesativity of it is not enough? Can i adjust these switches?
- You can easily apart the soleniod valve and clean it (from scale or other dirt). Be aware you should unplug the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Aug 14, 2007
- Did you disconnected one of the wires connected to the soleniod while measuring its resistance ? In case of a positive answer, you should open again the soleniod and clean it from any scale !!!!
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies LL64WNA
ariston lsi 61 dishwasher kept stopping half way through wash cycle.but now unable to select any...
(More)
ariston lsi 61 dishwasher kept stopping half way through wash cycle.but now unable to select any program as green light comes on for a few seconds then goes out.the power light is on ok
I have the above dishwasher and it stops half way through the cycle and refuses to drain. The salt...
(More)
I have the above dishwasher and it stops half way through the cycle and refuses to drain. The salt and rinse aid level lights are on. Could it be that I just need to top them up. I have checked the instructions but they are not very clear on whether low levels would cause the washer to stop working. Thanks in advance.
We live in Perth Australia and have this dishwasher in our rental house. It does not have a manual...
(More)
We live in Perth Australia and have this dishwasher in our rental house. It does not have a manual and we are having trouble with it. Please help.
The last time it broke down i replaced the element when it carried on for another two years.I have...
(More)
The last time it broke down i replaced the element when it carried on for another two years.I have now replaced the thermostat next to the element but still no luck can you sugest what else to try. The fan is running whilst drying and there is power to both the heater element and the thermostat but nothing completes the circuit
We bought a new machine for our little gite in France to rent out. It has never been used and only...
(More)
We bought a new machine for our little gite in France to rent out. It has never been used and only now are we renting the gite, so started the new machine to check it out. The eco light/soak light flashes and it says that the filter is blocked, but as it is brand new - of course it isn't! Filled salt to required level and that light flashes also. We have tried filling it manually with a little water and checked all inlets and outlets and even took the bottom panel off to check coneections, all fine and obviously brand new. As we didnt try it last year, it is out of warranty!!! Can anyone help - the filter is clean and all connnections are fine!
