Question about Koss KS2503 System
PLAYING DVD PLAYS DVD IN BLACK AND WHITE HOOKED UP DIRECTLY TO TV WITH WHITE/RED/YELLOW WIRES THEN TRIED WITH THE PRONG WIRE WORKS BOTH WAYS BUT PIC IS IN BLACK AND WHITE PLEASE HELP
  • 3 Answers
The unit is probably in pal mode. You need to set it to ntsc instead.
Posted on Mar 02, 2010
  • 56 Answers
Check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Posted on Aug 15, 2007
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
Coby DVD-937 playing DVDs in Black and White
you did not connect it to the right port in you tv with the right cables. if it came with a cable using red, blue, and green wire you need to connect all three to the appropriate place on the tv in this case the red is a video cable and not audio they are white and black in component video... if it is the other way around you have a red white and yellow cable the red and white are audio and yellow is the only video and needs to be connected to a yellow jack on the television
Jun 23, 2009 | Televison & Video
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Dec 27, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
S-video?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
Mar 16, 2008 | Philips Magnavox 42MF521D/37 Television
Koss KS2503 System Logo
401 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
