Question about Smart Modular PYXSCAPE SV1170 17" Flat Panel LCD Monitor
Off center screen
The image is off center. I cannot see the desktop toolbar and the left hand side is cut off. I have black space at top and left. What now?
  • Timberscot Aug 14, 2007
    I do not find a "menu" button on the computer.
  • Anonymous Apr 14, 2008
    I bought a new computer and the image is off center.
    Problem Solver:
  • 10 Answers
On the computer there is a button called menu press it. use the position tool and put both of them equal eg 50-50
Posted on Aug 13, 2007
SOURCE:
Grey side bar on desk top screen
The picture or image you have chosen does not fit the screen. Go to your system preferences, Desktop &Screen Saver, click on the desktop tab and change the image to "fit the screen" or a variety of other options.
Nov 09, 2013 | Apple Computers & Internet
We have a Canon imageRUNNER 3230. Starting this morning, it has been printing everything off center. If you send a document to the copier for printing, it shifts the image to the left so that the far...
I would make sure that the paper guides in the paper tray are tight against the paper. And make sure the adf guides are close togather so the paper will not go in crocked Good Luck.
May 20, 2013 | Canon imageRUNNER 3230 Black and White...
Screen on side
You can use the desktop toolbar on your computer to help you navigate around your computer, gaining access to programs and files. You may have previously moved the toolbar to the side of your desktop intentionally or accidentally. You can move the toolbar back to its original position at the bottom of the screen and lock it in place to prevent it from being accidentally moved in the future.
Right-click on the toolbar at the side of your desktop with your mouse. Locate the "Lock the toolbar" option in the drop-down menu. If it has a tick next to it, this means it is secured in place. Left-click on the button with your mouse to unlock the toolbar. Left-click on the toolbar, and drag it to the bottom of the screen. Right-click on the toolbar, and select "Lock the toolbar" to fix the toolbar in place at the bottom of the screen. Hope this helps.
Dec 08, 2012 | Google Toolbar
There used to be boxes top left side of my screen, File - Edit - Favourites etc. These enabled me to copy, cut & paste etc but they are now only available while using word. How can I reinstate for
If you are using Windows XP or Vista try clicking on the Tools at the top right of the browser. Click Tools, then click Toolbars, then click Menu Bar for it to remain there each time you open the browser.
If you are using Windows 7 press and hold the ALT key then release it. You will see the Menu Bar pop up near the top of the browser. Click View, then Toolbars, then Menu Bar and it will remain there each time you open the browser.
Apr 18, 2012 | Lenovo Computers & Internet
I have my monitor plugged in with a hdmi cable to my ati radeon hd 5750 video car and everything has the latest drivers but I still haven't filled up the screen. There is a 1.25" black margin on the sides...
It's an under-scanning problem. The setting to correct this is in the Catalyst Control Center Advanced settings. Upper left is a drop-down menu 'Graphics', from there chose 'Desktops
Aug 05, 2010 | Dell ST2210 21" Monitor
Black on two sides of monitor
For the Start menu, I assume you're talking about the taskbar that appears on the bottom of the screen. Press the Windows button on the keyboard (usually located between the Ctrl and Alt button on the left hand side).Right-click on the Start button. Click on the Taskbar tab and check the box that says "Lock the taskbar". Your taskbar should return to your desktop.
Wallpaper (desktop image)
In XP:
Right click on a blank space anywhere on the desktop. Click on graphics properties. You should see a window with your Wallpaper previewed in the top window. Click in the Settings. There should be a setting for "Stretch". Select Stretch and your desktop should return to normal.
In Vista: Right click on a blank space on the desktop, click personalize/display settings/advanced settings Click on your graphics card if available or graphics properties. You're looking for Aspect Ratio options From here you will see a setting with 2 options
  1. Maintain aspect ratio
  2. Full screen (no border)
Depending on your graphics card, this process may differ slightly, but the setting you need is Aspect Ratio
I hope this answers your questions. Best of luck.
Greg
Jun 15, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Sep 22, 2007 | LG RU-44SZ51D 44" Rear Projection...
Smart Modular PYXSCAPE SV1170 17" Flat Panel LCD Monitor Logo
199 people viewed this question
Top Smart Modular Computers & Internet Experts
Pamela Bates
Pamela Bates
dboyz
 Mike M
Mike M
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
