Home | Toshiba | SD-P1400 Portable DVD Player with Screen | Toshiba sd-p1400 dvd pla...
Toshiba SD-P1400 Portable DVD Player with Screen
Problem for Toshiba SD-P1400 Portable DVD Player with Screen
Toshiba sd-p1400 dvd player not detecting discs
By J3RRY on Aug 13, 2007
My Dvd player won't read discs, I tried running a cleaner disc to clean the lens, but it still won't read. I found out that if I open the disc lid and hold down on the disc lid button- such that the player thinks the lid is closed- I can watch as the reader tries to read the disc. When it tries to read, the disc doesn't hardly spin, but acts like it is trying to. I took my finger and spun the disc fairly fast and then held down on the disc lid button, and then I took off and spun the disc and read and played it. Is the motor bad or something? Thanks
Same Problem
Oct 21, 2008
-   i have the same problem...no matter how much i clean the discs the dvdplayer just keeps trying to read it...it says loading for about 3 minutes and then says" no disc" or "cannot read disc". what is the solution. this dvd player is only 3 weeks old...this so should not be happening!-   cookie1021
Solution #1
posted on May 24, 2008
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 567 votes
i think the motor is bad since its nt spining u can change the motor
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-P1400 Portable DVD
Questions and Unsolved Problems for Toshiba SD-P1400 Portable DVD
Do you recommend Toshiba SD-P1400 Portable DVD Player with Screen?
Answer
Answer
Toshiba model # SD-P1400 was working fine however when we tried to play recently the screen was... (More)
Answer
switch power on/off no good .. broken for sometime i did pushed or press very hard with the... (More)
Answer
Model # SD-P91SKN will no longer spin the discs. When I try to play a disc, it reads "No Valid... (More)
Answer
I have a Toshiba SD-P1400 portable dvd player. I can hear the dvd but there is no picture. HELP!!
Answer
The player does not read the DVD and some VCDs. I have had the problem for months
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba SD-P1400 Portable DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
