I fogot the BIOS supervisor passwrd
Check Out:
http://www.tech-faq.com/ibm-thinkpad-bios-password.shtml
Good Luck
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
SOURCE: BIOS LOCKED WITH UNKNOWN PASSWORD
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: ibm thinkpad x61 reset to original bios
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: when I power up IBM
OR
there is one more way to break password for many laptop ..u need to made serial port or printer port and there is software for it ...
Thanks
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
i cannot found the password pads
