Question about Bernina 1008
My machine stiches automatically when turned on! Help
The machine is plugged in and automatically stiches at a fast pace. I am not using the foot pedal, the pedal is not jammed.
  • tryingharder Nov 05, 2007
    Hi My Janome 3500 wouldn't stop, the foot control appeared to be working but the machine kept running and even accelerated. I think dust and fibres jammed it??? after a good shake (the foot control) it appears to be ok. at least temporarily
  • Anonymous Mar 12, 2014
    I plugged my machine on and tested the foot pedal. The ran for about 1 second and then stopped. So, I turned it off and turned it back on again. Now it won't do anything exept make a humming noise.
  • 202 Answers
It could be because there is a wire pinched in the covers to look for or a bad L-print circuit board BUT... Because the foot pedal is not jammed does not mean it isn't working correctly. Inside the foot pedal are two big springs that lift up what is called a carbon pin housing (that has a hook that attaches to the top of the footcontrol)that has carbon contacts attached to it. When these are lifted up the machine is stopped. When you press the footcontrol down it presses the contacts down and speeds up the machine. So somehow this carbon pin housing hook has become disengaged from the footcontrol and the contacts are sitting at the bottom allowing your machine to start at full speed. If your not afraid to fix this yourself heres what you do... 1. With a small screwdriver go through the tiny hole on the bottom of the foot control and adjust the potentiometer. (the potentiometer will only turn 3/4 of a revolution.) 2. Hold the foot control while removing the 4 screws and the two bridges. 3. Carefully release the housing (spring pressure) but do not pull the housing apart. 4. The top and bottom cover are connected by a hook. (if its not broken off) I think this is your problem since most likely the hook has become unattached. At this point though it would be good for you to clean the strips that the 2 carbon pins slide on with a q-tip and remove old carbon residue. Check to make sure the 2 little black carbon pins are not broken. (if they were the machine would not run at all). Be careful not to hurt the carbon pins) 5. To put this back togeather properly... insert the carbon pin housing into the bottom housing of the foot control (if you took it completely out). 6. Insert the two springs 7. Insert the top cover and hold it down while installing the 2 bridges with the 4 screws. to connect the hook follow the rest of the procedure... 8. Press the bottom and top togeather until 2 loud "clacks" can be heard. The clacks indicate that the hook engaged into the latch. 9. Now operate the footcontrol several times by hand up and down. It must be possible to hear clearly the soft clicking of the micro switch. If the clicking of the micro switch cannot be heard repeat step 1. Good luck. Your only next step will be to bring it to a tech or get a new footcontrol. (spendy) Rick.
Posted on Aug 27, 2007
SOURCE:
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Sep 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
244 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
