Question about Compaq MV 9500 (Carbon, Silver) 19 in.CRT Conventional Monitor
Monitor out of range
When i try plating games the monitor gives a massage saying out of range and it gives me the hertz. what can i do to solve the problem
  • 63 Answers
What Hz is it giving you? If it is less that 60Hz, you need to go into the monitor setup and raise the frequency up to 60Hz minimum. If it is higher than 75Hz, lower it to 60Hz.
Posted on Aug 14, 2007
SOURCE:
I installed the game whenever i open it i get Remark on monitor Out of Range. 53.5khz 85hz
That error message means the game uses a screen refresh rate that is beyond or below what your monitor can display.
You must find the game option (setting) somewhere in the game and change it.
60 hertz to 75 hertz is normal for most monitors.
Mar 17, 2011 | Computers & Internet
Refresh rate will not switch to 60 hertz from 59 hertz. Hence my hdmi connection from my desktop to my display keeps showing "out of range" error
turn off the computer restart it and press F8 immediatly before start and keep pressing untill menu appears then highlight on" enable vga mode" and press enter your problem will be solved
Apr 05, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
My monitor keeps saying "out of range" what can I do. My computer only goes up to 75 hertz and the monitor says 85 hertz. How can I fix this
Look up your monitor and your computer.
Your monitor maxes out at 75 Hertz
Your computer video card should be adjustable, but was unable to confirm, so try this:
Control Panel
Display
Settings
Inside of settings "advanced"
Set it to 75 Hertz
Feb 19, 2010 | Computers & Internet
Installed wed cam and monitor shut down with a promt saying "frequency out of range". Changed resolution settings still have a problem with monitor and this promt. Changed to another monitor and everything...
Connect the monitor that works.
In the "Advanced" settings for the video-card,
set the "refresh-rate" to 60 Hertz.
Connect the other monitor -- it _very-likely_ will support a 60 Hertz refresh-rate.
Jan 24, 2010 | Gateway HD2200 LCD Monitor
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Aug 24, 2009 | Soyo Computers & Internet
Vx710
The power supply is shot, sadly, and you'll need to replace it. It's inside the cover and you should be able to find one on eBay. I have one, which is doing the same thing. It's not the connection, drivers or updates. Not the Hertz (refresh rate) or Resolution either. Hertz too high will give an "Out of Sync/Range" (either/or) box in the middle. Same place you'd see "No Signal" if the cable was disconnected.
Aug 21, 2008 | ViewSonic VX900 19" LCD Monitor
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
Compaq MV 9500 (Carbon, Silver) 19 in.CRT Conventional Monitor Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
