Question about Hoover 9.9 cu. ft. / 280 liter Upright Freezer HVA280K
Hoover HNU271AFFAL I have this "frost free" freezer & have to manually defrost it every 2 months or so as the fan in it seems to get stuck ( I assume with ice?)After that it works fine for a while. It is only one year old! Are these frost free units known to be very unreliable? I had an old LEC conventional freezer for 22 years before that only needed a defrost every 3 years or so & never let me down! I am seriously thinking of dumping this & buying another conventional unit as I am fed up of losing all my food. Maybe they need another few years to get these working reliably? I think any device with a fan in it would be prone to failures? can you recommend a good one to buy? ( at least 8 cu ft, upright)
  • 1 more comment
  • Anonymous Jun 04, 2008
    my freezer is not workin i can use the super button only
  • Anonymous Jun 07, 2008
    i have just had the same problem i left the freezer to thaw overnight and its working again
  • Anonymous Dec 20, 2008
    What is error 02, what i have to do? Thanks
  • 46 Answers
As an ex hoover eng. these so called frost free units were never frost free!!!! if the unit was over gased in the factory it will over freeze. some early units were fitted with faulty modules and sensors. which were recalled thru engineer van stock but not to the public. call the service there service dept. but be careful not all hoover/candy/gias engineers are trained in refrigeration ( ask for a senior engineer. the staff turn over is huge!
Posted on Feb 07, 2008
Leave it to defrost it workrd for me
Posted on Jun 07, 2008
    Novelist:
  • 87 Answers
If the unit is only one year old go back to th point of purchase and ask for support. You may well have warranty. If not then you have a problem with the defrost cycle which could be the heater, defrost stat or defrost timer. I would suggest contacting an engineer if you get nowhere with the supplier. Hope this helps.
Posted on Aug 18, 2007
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
https://apwagner.wordpress.com/2008/.../22/5-common-freezer-problem...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
askville.amazon.com/freezer-suddenly-frosting/AnswerViewer.do?...
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ...
www.shopyourway.com > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
Is this freezer manual defrost or frost free?
Well, it would have helped had you included the actual model number, but without that, if you have a fan that blows air from the freezer into the fresh food compartement, its an automatic defrost design, A.K.A frost free.
Oct 02, 2010 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
FROST AND ALARM LIGHT ON
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
May 04, 2009 | Hoover Freezers
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Freezer frosting up
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Jul 10, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer freezing up
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Sep 16, 2007 | Freezers
Hoover 9.9 cu. ft. / 280 liter Upright Freezer HVA280K Logo
316 people viewed this question
Top Hoover Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Hoover Freezer Expert? Answer questions, earn points and help others
