My printer knows there is ink, but the black is not printing. If I put a cyan cartridge in the black position, it will print. The black is a new cartridge and it is printing in small patches. It was fine until the previous cartridge ran out when I was in the middle of printing pages of a document.
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
SOURCE: Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
SOURCE: Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
