Question about HP Compaq Presario V2000 Notebook
Unstable power When my modem quit working someone told me to take it out and blow it out to clean. I did that then put it back together,now when i turn it on in a few seconds or so it shuts off. even when it shows battery is on charge it also shuts down.
  • stayc5968 Aug 15, 2007
    i would like to say thank you to u both for trying to help me with my problem.
  • 63 Answers
Sounds as if you may have pinched a wire when reinstalling the modem. I would suggest going thru the same steps you did to remove the modem and check to see if a wire is chaffed, crushed or pinched.
Posted on Aug 14, 2007
  • 60 Answers
It sounds to me alot like youve got a short going on somewhere. unless your experienced in laptop disassembly and reasemmbly then its quite likely that you possibly put the wrong screw back somewhere or removed some insulating tape somewhere. Id recommend opening it up and checking it out if you feel confident. If not let the proffetionals take a look.
SOURCE:
2000 f150 not starting
I would start by checking to see if the battery cables are clean and tight. Look for broke or disconnected wiring. Is the shifter all the way in the park position? Chek to see if the starter motor pinion is jammed in flywheel ring gear. Starter solenoid might be faulty. Then check the ignition switch and system. Hope that Helps.
Feb 02, 2014 | GMC Cars & Trucks
I have a kenmore dryer 66702690. It quit working
unplug it,pull it out and take off the vent line and remove the back wall,you'll see the thermal fuse to the right of the duct that your lint filter slides into,part 3392519,pull one of the wires off and read it out with meter,if it's bad do a clean out on the dryer,remove the duct that the filter slides into and clean it out,blow out the vent line,i use a leaf blower to do this if it's a long run from the dryer to the outside flapper,don't forget to take out the two screws on top where the filter is to remove the duct,put it back together and remove the front and clean out the inside of dryer,do the clean out once a year for maintenance,if the fuse is good make sure you're getting 240 volts to dryer and power to motor,could have a bad timer?also check the t stats on the heater box,hope this helps
Feb 06, 2010 | Kenmore Dryers
I HAVE A VERMONT CASTINGS RADIANCE HEATER MY PILOT LIGHT WONT STAY LIT I HEAR THE THERMOCOUPLER TRIP THE VALVE BUT THE FLAME WILL GO OUT
We had this problem and struggled with it for over a year. We finally hired someone to come in and service the stove he cleaned everything and blew a piece of crud from the pilot line. NO Problem for 2 years since.
He told me the pilot light should look strong pointed like a pencil not curved up like a candle. He removed the pilot and disassembleed the line and used compressed air.
Jan 08, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Power problem
It may or may not.
Getting an item wet is not as bad as one might assume as long as:
1. you dry it out as fast as possible.
2. you quit running electricity through it
3. no transformers or absorbing electronics get wet
You always should kil the power to any wet electronics to keep them from shorting out. Then take it a part and blow dry everything till nice and parched. As for # 3 it is more of a prayer than anything because some electonice components such as transformers and capacitors can hold water even after drying and will make a nice mess once electricity starts coursing through it.
Mar 30, 2009 | Sony PlayStation 2 (PS2) Console
PS2 TROUBLE SHOOTING/ POWER
Hi, I think what probaly happened was when you were cleaning it you pulled out a wire or cable. When you clean you have to be careful, you should always go onto a website check how it is done. The best thing to do is to take it to someone who can repair for you.(It does not cost much) Hope it works again.
Jul 04, 2007 | Sony PlayStation 2 (PS2) Console
HP Compaq Presario V2000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
