Question about Symphonic ST420FF 20" TV
Lost remote How can I get an x-box game to play on the tv if I have lost the remote. I can not get an aux or input channel on my tv, please help.
  • 979 Answers
Sorry, got to have the remote for this set...accordianman
Posted on Oct 20, 2007
SOURCE:
I lost my remote for my durabrand tv i dont know how to check what model it is because i dont have the box... so i cant change to the game or input or aux function because i want to play video games but i...
All tv's have a sticker on the back with the model number clearly printed on it.
Most Durabrand tv's have a Source button on the case, use it to switch to the game console AV entry and back to the tv.
Aug 04, 2010 | Televison & Video
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is There a way to go to video/input without a remote.
My answer will be generic.
With many of these TV sets the original factory remote is required to change the input mode of the set, or to access any of the user menus.
On some models of sets, putting the channel selection down to below channel 2, puts the TV in to the external input modes.
Jerry G.
Feb 10, 2009 | Emerson Televison & Video
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Nov 21, 2007 | Orion1934 19" TV
Aux channel
Press channel down until you get to channel 1 then press channel down one more time ,this should give you your AUX.If it doesnt try going into the menu and doing an autoprogram with the video game hooked up and turned on.
Nov 08, 2007 | SansuiM1315 TV
Symphonic ST420FF 20" TV Logo
448 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
