Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Canon SD630 Image Problem
Hi - my son dropped his 6 mo. old SD630. images are now very overexposed or have vertical stripes throughout. He has reseated the card, removed and replaced the batteries; and checked the settings to make sure exposure wasn't changed. Any suggestions on how to proceed? Otherwise, camera has been fantastic! Thanks in advance. M
    Genius:
  • 2,985 Answers
Canon customer support - keep quiet about the dropping thereof. You may get a replacement under warranty
Posted on Aug 14, 2007
SOURCE:
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Image extremely overexposed and has horizontal banding
CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Mar 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have an Olympus 1010. I took a few pics of my son, changed his outfit, and now all the pics are white, like they are overexposed. I have played with every setting on the camera with no luck
What happens if you try to reset the camera back to its factory settings. Does it still overexpose the images? TO reset the camera go to Menu - left arrow to Reset - press Ok - up arrow to Yes and press Ok. The camera will now be back in factory settings. If the images are still overexposed, it may be a repair issue with the image processing functionality.
Dec 15, 2008 | Olympus Stylus 1010 Digital Camera
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
I have problem with memory card in Canon Powe Shot SD630
The memor card is getting corrupted, have you tried formatting it as this should fix the problem. Format this on the camer and not on the computer.
Aug 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon SD400: horizontal lines and daylight images are overexposed (see photo)
In both the situations the problem is with the apperture control mechanism of the camera. 1). sometimes the flexible ribbion cable carrying signal to the lense assembly get worn out, replacing the same will resolve the problem. 2) in some cases the leaf blades of the apperture gets sticky, cleaning of the same solves the problem. 3). If you happen to drop the camera then the alignment of the motor moving the blades get disturbed.
In all the cases only a good repair man can fix the problem .
Jun 02, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera overexposes on daylight and recorded images have hoizontal striping
I would take it off of automatic mode and adjust it manually.
The Samsung camera I have doesn't work very well in automatic mode under indoor conditions. It will work in automatic under outdoor conditions.
Hope that helps.
Mar 24, 2008 | Samsung Digimax L60 Digital Camera
Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Oct 18, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
