Question about Panasonic SC-HT70 System
Panasonic sa-ht70 after pressing the power button, unit goes back into standy immediately
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!
Posted on Jan 28, 2008
Débranche du secteur et rebranche = OK !
Posted on Mar 16, 2008
SOURCE: Panasonic SA-HT740
I get this error usually once during a movie. Sometimes it is 10 minutes into it, sometimes it is an hour, and the only thing I have ever been able to do to get it to work, is to unplug the black power cord from the unit, for 20 seconds, and then reconnect it, and it usually works for the remainder of the movie. Would like to see a better fix, however!!
Posted on Oct 09, 2008
  • 336 Answers
SOURCE: My sa-ht70 wont go above 0db on the volume
Check and lower the speaker levels. Then see what the max is on the volume control.
Posted on Mar 01, 2009
SOURCE: plays only cd's no dvd's reads no disc
The laser lens would have got repaired inside. Please change it.IT will read the dvds. It cost about 25$ i suppose
Posted on Mar 04, 2009
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
Hope this helps
Posted on Jun 09, 2009
0 characters
1 Points
I need a remote for as-ht70home theatre
Here is one on the Bay
PANASONIC Remote Control for SC HT70 SC HT65 SA HT70 SA HT65 Free Shipping
Couldn't find factory new available. Best bet may be a universal.
Jan 06, 2015 | Home Theater Systems
Panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Apr 03, 2013 | Panasonic Home Theater Systems
My panasonic sa-ht70 led stop displaying . Everything else seems to be operating fine.
The front board will need to be replaced. The front board has the buttons(i like the touch buttons in the Samsung HT-Z320) and te display.
Jun 23, 2010 | Panasonic Home Theater System System
My panasonic sa ht7o plays dvds fine but no
you have it hooked up as a component with one of the three video cables crossed
Aug 24, 2009 | Home Theater Systems
My sa-ht70 wont go above 0db on the volume control,it used to but wont now. Any help?
Mar 01, 2009 | Panasonic SC-HT70 System
Panasonic Sa Ht 70 Problem F61
Hi, F61 usually means that the unit has some sort of DC error internally. One of the amplifiers could have failed. The HT70 is an older unit and dry joints around the voltage regulator and power amplifier is also very common. Also check that the fan is in good order.The unit will most likely have to be checked by a professional tech.
Jul 12, 2008 | Panasonic Home Theater System System
To convert my SA-HT70 to multi-region
to unlock you dvd player just press play button and turn off the device at the same time .
Jul 04, 2008 | Home Theater Systems
Won't play
This DVD home theater system has a defect that is not being addressed by panasonic. The Optical lens and or DVD Motor will give out after 2 to 3 years for no reason. It will start saying "No Disc" and will not play any DVD or CD. To repair this it will cost you £100.00 to £135.00 to repair. An authorized panasonic repair company told me that if I repair this it will last me up to 3 years and I would have to fix the DVD Player again. The dvd player model number is SA-HT70 and the number for the system is SC-HT70. The SA-HT70 is the dvd player that is not reliable. Without warning in 2 to 3 years you will have to repair the optical lens or dvd motor which will not be covered by Panasonic.
Feb 12, 2007 | Panasonic SC-HT70 System
Panasonic SC-HT70 System Logo
90 people viewed this question
Top Panasonic Home Theater Systems Experts
Richard Roth
Richard Roth
Are you a Panasonic Home Theater System Expert? Answer questions, earn points and help others
