Question about Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Dishwasher won't start
When i turn my dishwasher on, it sounds as though it is going to work but suddenly stops after about 1 second. You can hear what sounds like the motor beginning to kick in and then it stops and you hear a quick swoosh of water if you put your ear to the base of the dishwasher. I have checked for power, cleaned the filter inside and tried the tip on how to start a stalled dishwasher but it is still not working. I have had the dishwasher out and unscrewed various parts of it to try and get to the motor but was afraid to go any further in case i forgot how to put everything back together again. Have you any suggestions or will i have to get a repairman out. Thanks.
  • Anonymous May 02, 2008
    i have the same problem with smeg st 663 fully integrated, close the door motor sounds for one second then stops and repeats this process continually.
Hi
WE give this answer in good faith that anybody who benefits from it will make a donation to COMIC RELIEF, because I've just fixed my smeg d/w which is a great relief and no joke when not working,
SO DONATE.
My dishwasher tried to start but would not ,it tried but could not, the panel showed no fault.
The fault was caused by the failure of the solinoid (electric magnet) which opens the soap dispenser mechanism, located inside the door. I used an electric light up screw drive (from £ shop) which glows when you touch the end, to test the solioid, you could also use a multi meter though not as reliable.
We replace solinoid, (Common solinoid from any appliance repair shop) but I note on ebay there is a dishwasher guy selling the complete dispenser unit with new solinoid fitted.
Hope this helps( we have just had our first wash)
Do not forget to donate
Minnie Moon (twitter)
P.S. Sorry I can not remember how to spell solinoid (electro magnet)
Posted on Mar 02, 2009
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Does not woork
Has the water drained by the time the dishwasher powers off?
The clicking sound is probably the (failed) pump motor and will require a service call or replacement of the unit.
Mar 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Bosch sgs6302gb
the problem is the circulation motor needs to be loosen up take a 5'16 driver open the filter on the bottom and loosen it at froom thr small hole on the left.
Dec 10, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher Fails to turn on
It sound as a control board problem. you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck!
Sep 12, 2007 | Dishwashers
Smeg 24 in. DWD1SSE-1 Built-in Dishwasher Logo
559 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
