Question about ASUS A8S-X Motherboard
As8-v abit motherboard
Boots up after 10 seconds and cuts out and there is a light on the motherboard and stops at 9.F.
    Novelist:
  • 231 Answers
Hi, the most common cause of this type of problem is the on/off switch on your case. See if you can get a spare one from another computer and plug it onto your board in place of the original one for a test. If this is not the cause then it would be worth checking the power supply, even if there is a LEED light on the motherboard there could still be insufficeint power to boot up. Regretablely the next conclusion is your motherboard. Goodluck with this regards mistyman
Posted on Aug 14, 2007
SOURCE:
Code C0
Try clearing your CMOS it might be a bad BIOS setting preventing it from booting, also if you have a spare memory chip laying around or can borrow one from somebody try booting it with different RAM
Dec 06, 2013 | Abit AS8-V Motherboard
Abit 1-450c manual
http://www.ps2netdrivers.net/drivers/abit.as8/
Mar 05, 2013 | Abit Computers & Internet
Abit as8 post codes 21
Hello here is the homepage:
http://abit.ws/page/mi/download/[email protected]_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AS8&pSOCKET_TYPE=LGA775
Post code 21, is a memory/ chipset problem.
It could be a problem with a ram module, or a Pci sound card or a graphic card. or powersupply.
Try to remove any add in cards, and try to boot with only one stick of ram.
Good luck
Jan 12, 2013 | Abit AS8 Motherboard
My computer wont turn on lights up but wont turn on
What did you do in bios ?
You might have to go back into bios and set fail safe or optimized defaults.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Dec 22, 2012 | Abit AS8 Motherboard
I get a POST code of 00 then after i hit the power on i get 83 then 96 then 9.F. help my pc wont start and i`ts no beeps.
If no beeps your MOBO is fried.Is no worth to try to fix.Instead i suggest to get a new one.
Dec 19, 2010 | Abit AS8-V Motherboard
I picked up a discarded complete computer with Abit AS8-V motherboard and standard CPU. The entire assembly had been immersed in floodwater. After cleaning, drying, and waiting a few days I powered it up....
Simple test: disconnect the hard drive and the optical unit and try to boot in BIOS. If you can't then the first thing you should check is the memory, followed by the processor. If you can then the hard drive is dead.
Mar 13, 2010 | Abit : AS8-V...
Board won't pass post code 18 and not sure what or why
Postcode error 18 ( Usually means ) System timer fail.
re-seat The RAM ( Memory ) or check the memory is of the Correct Type for the Motherboard. ( DDR-DDR2 )
This is most Likely A RAM Problem.
Mike @ Compurepair.
Dec 01, 2009 | Abit AS8 Motherboard
Can i?
An attractive value of dual core processors is that they do not require a new motherboard, but can be used in existing boards that feature the correct socket. Check sockets if same then enjoy.
Jun 05, 2009 | Abit AS8 Motherboard
Open Questions:
See all ASUS A8S-X Motherboard Questions
ASUS A8S-X Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
