Question about HP LaserJet 4L Printer
Power Ok this might sound bad... but i can't get my HP LJ 4l to switch on. the on/off botton has become dislodged. . I got the printer second hand a few weeks ago and was fine but all of a sudden one day . it wouldn't go on.. please Any helpful suggestions ?
  • Diggernan Nov 17, 2007
    All connections appear to be OK. Printer does not respond.
    Do these things just die??
  • Anonymous Dec 11, 2007
    My Laserjet 4L one day just wouldn't turn on when I sent a document to it. I disconnected the I/O cable, pushed the blue top button (below the error lights) and nothing happens.
    As I moved shortly thereafter, I've misplaced my operating manual.
    Is there a fuse or hidden switch which could be preventing the printer from powering up?
    Without connecting the I/O cable, shouldn't the blue button when depressed cause a print test sheet to be generated? Would it help in troubleshooting/repair if I reconnect the I/O cable?
    Any advice would be appreciated.
  • HP Master
  • 705 Answers
Replace the power switch. A fairly standard switch type. You may get one off ebay or similar site. If push came to shove, you could just replace the power input assy.
Posted on Oct 18, 2007
SOURCE:
I have a customer which is running a old DOS PC using Parallel I/O with a down HP LJ 4L needs a DC Controller PCB which I cannot find. Can you use any type Printer in the series, such as 4ML, 4P or 4 MP...
In general, yes. Some model-specific features won't work with other models, of course. For example the 4P does PostScript while the 4 does not. But as long as the customer confines himself to basic printing, the 4L driver should work properly with any of the 4-series printers.
Feb 27, 2013 | HP LaserJet 4L Printer
I bought a new machine hp laserjet 4350n but I cannot locate the power switch botton. Pls help me.
Hi, the power switch button (on/off switch) is shown as Number 5 in the diagram below, on the right hand side of the printer at the bottom:
Apr 12, 2011 | HP LaserJet 4350 Printer
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
HP Laser 4L driver for USB port
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
Jul 21, 2009 | HP LaserJet 4L Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
Hp lj 2015dn problem for top 2 LED standard ON in my printer
check your printer motherboard it could be the communication cable from the power board is bad or the mother board that is why it can not scan. that is the problem
May 23, 2009 | HP LaserJet P2015dn Printer
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
HP LJ II P plus
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
Jul 25, 2008 | HP LaserJet IIp plus Printer
HP LaserJet 4L Printer Logo
120 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
