Question about Kodak EasyShare V1003 Digital Camera
Damaged LCD Screen
While in a "protective case", my Kodak V1003 fell to the floor and damaged it's screen. The LCD resembles a cracked windshield with vertical colorful lines and random black blots of ink on it. Would it cost more to have it repaired opposed to buying another camera?
  • 11 more comments
  • stee1hed Nov 09, 2007
    The lcd screen on my v1003 is also cracked. Does anyone know where I could get just the lcd screen for the camera?
  • catfisch Nov 26, 2007
    I purchased a new lcd screen but received no instructions on replacing my cracked screen. How can I find out how to get the camera apart to replace the cracked screen.
  • ArtieH Dec 16, 2007
    The screen broke while my daughter was carrying the camera in her bag. The camera is out of warranty.
  • Anonymous Dec 23, 2007
    My V1003 was in it's case, but the nex time I turned it on the LCD screen was cracked internally.
  • sk8ermom Mar 09, 2008
    My daughter has the v803 and while it was in her bag the lcd screen suddenly broke. We now have a leaf shaped design in black with a white screen can anyone tell me what to do it is still under warranty and I bought an extened warranty but now Kodak says if the think it is her fault it will cost me more money
  • Anonymous Jun 21, 2008
    my lcd screen cracked too, i think my camera was thrown, or dropped. but im not very thrilled about it. how can i fix it??
  • Anonymous Jun 23, 2008
    Very interesting. I bought the camera for my son in July 2007. Three weeks later he had it in his pocket, sat down, and found the screen cracked internally. Seems to be a common problem, maybe a defect in the camera?
    Hello Kodak? Redance@sbcglobal.net
  • Anonymous Jun 26, 2008
    My son was carrying my camera in his pocket, sat down and the screen broke. My daughter, who has the same camera, has the problem of the lens not retracting and now there is a piece of something rattling around inside. I was thinking I could use her LCD display to replace my broken one but didn't know how. It would be better than junking both of our cameras. I believe both problems are probably a design defect :(
  • melissarynn Jul 22, 2008
    I had my phone next to me on the bed while i was sitting on it for a second turned off, the next time I turned it on low and behold the screen had done the same as the other guys here! Really really annoyed!
  • Anonymous Aug 06, 2008
    I left my camera on the microwave and the next morning I went to use it and the lcd was broken.
  • JayCzzya Oct 12, 2008
    I have a samsung l700 and I have a similiar problem. I forgot my camera in my back pocket and although it was in a "protective case" the screen cracked internally. Is it worth it buying a new screen or would it be cheaper to buy a new camera? If so, where can i get a replacement screen for my camera?
  • melissarynn Jan 07, 2009
    I earlier wrote my phone but I did mean my camera, who knows why I put phone!
    I went and asked in a camera shop what would be cheaper; a new screen or a new camera. I was told that despite it being a good camera, it was much cheaper and probably amuch better idea to get a new camera rather than a new screen. I now have a big panasonic lumix camera and it is amazing, no problems of yet with that!
  • owentate1990 Mar 17, 2009
    how to change screen on a V1003 kodak
  • 2,130 Answers
The following procedure works on the V1003. It uses the same LCD screen as the V803.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Posted on Feb 11, 2008
    Problem Solver:
  • 18 Answers
Go to www.buy202.com the lcd is $39.00 with free shipping and you can replace it your self its pretty easy i did, just need a eye glass screw driver. hope this helps
Posted on Sep 13, 2008
Beware, www.buy202.com is a scam! I ordered a screen for my Kodak and never received it. I ended up getting the charges reversed through my credit card. I checked today and their web site is no longer up, so maybe they got shut down. Here's another interesting comment about the scam:
http://www.infobarrel.com/How-To_Save_Money_by_Repairing_Digital_Camera_LCD_Screens
You're much better off ordering directly through Kodak. Here is a thread that contains that contact info. I ordered my screen here and got it within days. Good luck.
http://www.digitalcamera-hq.com/digital-cameras/kodak-easyshare-v1003_question.html?qid=17637
Posted on Jan 03, 2009
I broke my LCD screen for a kodak camera that cost $150 and got it repared for $70 but i recently bought a new v1003 kodak camera for $200. If your camera is in good shape exteriorly and you like it i would go with just replacing the lcd screen ...
Posted on Oct 15, 2007
SOURCE:
Kodak v1003 screen has no data (grey screen)
The cost to repair is about the same as the cost to replace and you must send it back to Kodak for repairs. About 6 weeks turnaround.
Jul 14, 2017 | Kodak EasyShare V1003 Digital Camera
Damaged LCD screen on my digital camera.
hi, you could try to contact here to get replacement of lcd screen for your camera: http://szaideal.diytrade.com/
Jun 08, 2009 | Kodak EasyShare V1003 Digital Camera
Cracked screen
no the screen is not worth gettin fixed the lcd scrren usaually cost more than the camera itself does but if your camera is discont get it fixed because their will be no other camera like it
Jun 02, 2009 | Kodak EasyShare V1003 Digital Camera
Screen on c530 Garmin is damaged. How much to repair?
It sounds like you've broken the LCD screen below the protective outer cover. It will have to be replaced. I don't know if this website can help you.
http://www.sharc.net/nuvi_repair_warranty.htm I am not affiliated with them.
Jan 13, 2009 | Garmin eTrex Legend GPS Receiver
Lcd cracked and bleeding spot down left part of screen
Go to www.kodak.com look for the customer service link or look for contact us ,then call and they will give you a return number
Hope this was of help!
Dec 11, 2008 | Kodak EasyShare V1003 Digital Camera
Casio Exilim 1050 broken screen
If it is simply a crack and other wize still OK
Best way is to go to a photo store and purchase lcd screen protector film or heavy duty transparent repair tape[camping store]
Taking a camera apart is no easy task unless your are used to fine instruments and reassembling them ditto
Buying spares new is a nono usually .Secondhand -well its a gamble isn't it?
If you can find the model you want and if it is in good nick.
Jan 07, 2008 | Kodak EasyShare V1003 Digital Camera
LCD screen replacement
I have a 6230 that had a cracked lcd. I purchased a parts camera on ebay for only a few bucks and the screen was easy enough to swap out.
Aug 28, 2006 | Kodak EasyShare CX7530 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
2,265 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
