Cars & Trucks Logo
Roger Conlon Posted on May 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Axles won't turn in same direction one will go back the other goes the goes forward
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on May 16, 2013
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058416
Points
266281
2 Related Answers
Anonymous
  • 24 Answers
  • Posted on Apr 11, 2012
SOURCE: 1995 Lincoln Continental, passenger seat won't tilt back forward
YOU HAVE A SWITCH OR A TILT ACTUATOR MOTOR PROBLEM. LINCOLNS HAVE 5 OR 6 ELECTRIC MOTORS MOUNTED ON THE UNDERSIDE OF EACH FRONT SEAT WHICH REQUIRES REMOVING THE SEAT TO INSPECT .THEIR ARE ALSO CABLES ATTATCHED TO THESE MOTORS SO LISTEN WHEN YOU HIT THE TILT SWITCH DO YOU HEAR A MOTOR NOISE? IF YOU DO THEN YOU MAY HAVE A BAD CABLE.
A
Anonymous
  • Posted on Nov 14, 2012
SOURCE: I've 2000 Mercedes Benz ML 320.One night I backed up & parked in the Garage the next morning it won't go forward. I noticed the that REAR WHEEL on passenger side was locked up. What's
The only suggestion is to place the vehicle on
stands & remove the wheel to check out the issue
To speculate from the internet-- is just that.
To have something happen while you sleep
is odd,so I would be inclined to go with something
like an electronic parking brake issue,if that applies
2000 Durango ignition key won't turn
you need to turn the key forward to remove the cylinder. its a safty measure. try a spare key or turning the wheel each direction hard while turning key. sometimes there is to much pressure on stering wheel lock to turn key
How do you know if cv axle is going bad
Turning them by hand to feel play
Pulling forward & backwards with the wheels
turned in either direction, to listen for popping
sound, is how you tell inside from outer joint
The entire axle gets replaced if a joint or boot goes
You can tell from noise while driving at different speeds
Only the guys at a trans shop have that kind of diagnostic
experience
Starter just clicks won't turn over
your starter is the 1 which is damaged n if they say or u check it n find that its gud then its your terminals they are loose somewhere
My rebuilt transmission won't go forward?
i would be checking the shifter cable adjustment first see how that goes goodluck
Why won't my 96 buick go forward or backwards
Well i would first check trans fluid in park with motor running. If fluid is good in color i mean red or a little dark then i would then check if it rolls in park the reason for that is to see if you had a axle pop out. Now if it holds in park your axle is fine. Next is the possibility of a bad transmission you may have broken the pump. One way to confirm is to disconnect one of the cooler lines and see if there is fluid pressure now this is dangerous and messy so i would recommend a shop to do this.
All wheel drive binding when turning sharp on my 2002 Volvo
SOUND LIKE A WORN HALF SHAFT CV JOINT.CHECK FRONT DRIVE AXLES LOOK FOR BUSTED DAMAGED BOOTS.IF BOOTS ARE DAMAGED YOU HAVE TO REPLACE THEM. YOU CAN RE OVER HAUL CV JOINT AND BOOTS BUT IT WILL BE CHEAPER TO BUY NEW ONE YOU NEED TOOLS TO REBUILD CV BOOTS AND AXLE.
I'm trying to remove the "hub" from the front axle because the rotor was rusted to it and a new one won't fit "true". I need a picture or exploded diagram to understand why it...
Your hub is a complete unit including wheel flange and bearing. Thje axle passes through the assembly. You will find three twelve point 13mm bolts that go into the rear of the hub through the steering knuckle.
To remove the assembly, Loosen those three bolts, run them out part way and use a socket you don't want (you will destroy it) Put the socket on each bolt and use a heavy hammer to drive the assembly out of the knuckle. Alternate sides so it does not bind. use lots of solvent on the hub parting surface.
One tip: Disconnect the tie rod end so the assembly is easy to turn from side to side.
The hub assembly is only rebuildable in a factory. It is replaced as a unit. While you have it apart, always check the axle universal for binding or play. If you remove the axle for any reason, when putting it back in don't drag it on the bottom of the tube, The seal is inside the tube next to the gear set. Dragging the axle will knock the seal out.
1helpful
1helpful
2001 grand voyager rear axle and barke part numbers and diagram
You go to dealers parts counter & have them put
what you want on the display & turn it so you can
point to what you want or write down parts #'s
You really shouldn't need any of that to repair your
vehicle.
An Auto Parts Store can do the same thing & you
can go behind the counter & check out parts
on their computer
The parts store won't use any dealer numbers at all
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
