Question about Cybernet Systems CyberPower 625AVR (cp625avr) UPS System
Wiring Fault light
My computer would not turn on and the "wiring fault" light is lit on the Cyber Power 625AVR. When I bypass the 625 and plug the computer directly to the wall socket, the computer works. Is my surge protector just done for?
  • thirtysixer Feb 18, 2008
    The wiring fault light is on and the on/off light is not on. The computer is plugged into the back three outlets and works okay. The sound amplifier is plugged into the front of the power system and it does not work. Would this indicate that the battery section of it is dead and the components will work only on the direct connection to the wall socket?
  • Anonymous Mar 09, 2008
    The same exact thing happened to me...I thought it was just done for...if anyone knows different, Please post.
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.sourceresearch.com/cyberpower/cyberpower-pdf.cfm?PdfPage=625_Manual.pdf The "wiring fault" could be serious, as per manual: "This LED indicator will illuminate to warn the user that a wiring problem exists, such as bad ground, missed ground, or reversed wiring. If this is illuminated, user is advised to disconnect all electrical equipment from the outlet and have an electrician check the outlet to insure proper ground." I would turn the UPS off, unplug all equipment, wait 10 seconds, reset the circuit breaker (if tripped) and turn the unit on. If you still have an issue then it's probably fried! Have you had any thunder storms or electrical power outages recently? Check your house insurance because it may cover a replacement unit. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
SOURCE:
What is error code 76 on a Rheem tankless hot water heater that has propane connection?
Communication Fault with Remote Control. At a minimum check the following: 1. Check remote control wiring for loose or damaged connections. 2. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Yes Either the wiring or the remote control is at fault. To rule out the wiring, disconnect the remote control and use a short, good jumper wire and connect directly to the remote terminal on the PCB. If the unit works using the remote, then the wiring is at fault. If the unit does not work, then the remote is at fault. Did the unit go to main burner? No Replace the Printed Circuit Board Remove remote control wires from wiring terminal on the PCB. Plug unit in and open a hot water source.
Dec 16, 2016 | Rheem Water Heaters
Fuse for tail lights keeps blowing
You have a serious short circuit in the wiring to the tail lights. Fuses protect the wiring in your vehicle from catching fire.
You need to trace the tail light wiring from the fuse box to the tail lights to locate the fault/short circuit.
A wiring diagram can help as it shows the colour code of the wires to the tail lights.
This problem can be difficult to trace and you most likely need an auto electrician to fix this problem. It could mean installing a new wire to the tail lights as a quicker fix and bypass the fault..
Apr 19, 2013 | 1993 Nissan Quest
Power button is not working. Green light is lit in back on power supply. Removed front panel. Clicked button and computer will not power on. Please help.
try another power supply, the light at the back indicates input power not output some diodes have probably blown resulting in the power not being output to the pc
Mar 03, 2011 | HP Media Center m7060n PC Desktop
Nececito la bateria para cyberpower 625 avr la tienen y cuanto cuesta
http://www.osibatteries.com/showproduct.aspx?ProductID=9521&SEName=cyber-power-office-power-avr-625avr-ups-system-battery
Here is the replacement battery. Open the unit, disconnect the old battery, connect the new battery, and put the unit back together.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Cybernet Systems CyberPower 625AVR...
On my Back-ups ES 550 the "Building Wiring Fault"
This red light usually indicated the ground on the outlet the UPS is connected to is not properly connected to ground.
It could also mean the ground and neutral wires on the connected outlet are reversed.
Nov 01, 2017 | AMD Computers & Internet
Wiring fault light on. What it is the problem?
most likely the outlet the unit is plugged into is not grounded, needs to be grounded for it to work properly
Sep 11, 2010 | CyberPower OfficePower 625AVR UPS System
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
JVC TH-C30 Digital Theater System
If there is no power at all, then try bypassing surge protector, check power cable, and check if power cord is fused.
If unit has power but does not start, then it is on protection.
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 11, 2009 | JVC SP-PW100 Subwoofer
Shutting down computer
You need a new battery. A battery store such as Batteries Plus can help you. Many Ace Hardware stores will order one for you and in fact, Radio Shack has the most common battery types in store or can get it for you. If you go through Cyber Power you will pay the highest price.
Hope this helped you.
Regards,
Worldvet
Please don't forget to rate all our solutions on Fix Ya.
Jul 02, 2008 | Cybernet Systems CyberPower 625AVR...
Cybernet Systems CyberPower 625AVR (cp625avr) UPS System Logo
620 people viewed this question
Top Cybernet Systems Computers & Internet Experts
Alun Cox
k24674
Are you a Cybernet Systems Computer and Internet Expert? Answer questions, earn points and help others
