Question about Sony KV-36FS17 36" TV
Sony MODEL KV-2585 TV
Q657 (Protechsion zener diode short circuite)and the TV makes a hissing sound. No picture or sound.
  • 1 more comment
  • Booysen Mzizi Aug 16, 2007
    Sony MODEL KV-2585 TV, everytime the TV is put on, Line Driver Transistor Q802 2SC4927 shorts out.
  • Booysen Mzizi Aug 18, 2007
    This advice is 50% helpfull. Sorry I had my information incorrectly reported. The Model is a Sony KV2585.
    From your advice, I have almost solved this problem:
    Q802 is not shorting anymore, but D657(Protechsion zener diode)shorts out as soon as I switch the TV on. Any clue?
  • Booysen Mzizi Aug 19, 2007
    Q657 serves as a 135v regulating zener as well for protection. It is on one of the Secondary output pins of the chopper tranformer,which isolates the power suply on its primary side,and supplkies the rest of the TV with power. As soon asthis is shorted,the set is in an overloaded stage,and thus the hissing sound fromthe transformer,and thus no standby by B+. Because this short is in the primary of the chopper, no fuse breaks,but thus the set is in a protected short. Regrads.
Can any one tell me KV-2585 vertical ic number..please...
Posted on May 31, 2013
I am trying to get the code for a universal remote for my sony kv-2785r . The directions for the remote doesnt seem to be accepted by the tv. Do you have the code for this model?
Thanks
Posted on Jan 17, 2008
    Problem Solver:
  • 18 Answers
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Posted on Aug 16, 2007
  • Donald Block Aug 17, 2007
    Ok, so you dont have a shorted diode after all, what else confuses me is your heading says KV32FS17 but your text say's KV2585. Now that transistor 2sc4927 is your HOT and if it keeps shorting then I would start checking other things in the Horizontal deflection. I dont have that chassis in my data log so Im just going to take some guesses. Check the flyback, do you have a Dick Smith flyback tester? Check all the electrolytic caps, and check all the resistors. Going out on a limb here I have a log for a KV2785R and I dont know if it is the same chassis or not but look for a resistor R555 if you have it check to see if it is open, if so Sony has an upgrade, let me know if you have that resistor and if it is open, I will give you the upgrade after we find out.
    Don
  • Donald Block Aug 19, 2007
    Ok, since I do not have the schematic there is not much more help I can be but I will try. We have determined That Q802 is your horizontal output, But what section is D657 in?? Is that the power supply? Or is it the vertical? Can you tell me? Since you did not answer me about that resistor (R555) I assume you do not have it in that set. Here's what I would do, since D657 shorts out every time you turn the set on I would check every thing associated with that diode, are you sure it is a zener? Check all the resistors in that circuit as well as any other diodes and check the electrolytics. If D657 is in the power supply check the voltage regulator, do you have a stand by B+ with the set just plugged in but not powered on? Let me know and take it from here.
    Don
Can not change channels. the image is snowy. dvd's play great.
The problem on that aspect is on the tv internal tuner section,on 33volts dc supply,,cause by the a shorted zener diode...,Dods
Sep 19, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Had power outage while tv was on. When power restored I turned on tv with remote. TV sounded like it went on but no picture. Only timer light lashing. Sony Wega older model 27" Please help, thanks
next time dont leave your tv pluged on power, the power supply got burnt, check your power supply on the following components
fuse, power transistor, zener diodes,also rectifier diodes
if you can manage do it at home
or take it to a w/shop
Apr 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Red standby light flashing no picture or sound
the power supply is faulty, check the following
power trasistor
rectifier diodes
zener diodes
fusable resistors ( less than 20ohms)
and your set will work again
Apr 07, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron (analog) picture suddenly ''pulsating''
the verticle has a problem check the following around that area
capacitors
zener diodes
resistors changing values
what is happening is that a voltage is not constant, its varing
Mar 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
Jan 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic
check the following, at the w/shop
power supply transistor,zener diodes, fusable resistor, line transistor, near line transformer,
your tv is not oscillating so even the ht voltage of 90-110v from power supply be checked.
Nov 13, 2007 | Sony KV-36XBR450 36" TV
Your assistance
The Sony part number for these diodes is 8-719-108-12 and yes they are 9.1 volt zener diodes @ 1 watt. I have the service manual for this set if you need it put can only send a large file like this trough a proggy called pand, so if you go to pando.com and get the proggy and leave youe e-mail addy I will send you a copy of this service manual. Good Luck
Mar 26, 2007 | Sony KV-27S65 27" TV
NO Picture On 2 Video Inputs ( 1 front 1 rear ) : Sound OKAY
Since it is 5 years old mostly dry soldered appears. First sort out the soldered problem. Then check zener diode in video input path is short. Mostly the diode is short. Still get problem check video switching ic also. I think former is the most problem.
Dec 13, 2006 | Sony KV-36FS12 36" TV
Sony KV-36FS17 36" TV Logo
514 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
