Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Glass breaking Hi, The continuing saga of my Smeg A2-5 oven... Having had the element go "POP!" and replacing it the main overn glass then shattered. I replaced that and, rather annoyingly, the glass has shattered again. Now, I've always felt that the oven runs very very hot but am in two minds whether it is the thermostat that may be faulty. The red thermostat light goes on and off but could it still be faulty? Best regards!
  • Faultyhouse Feb 20, 2008
    Hi
    I have had a smeg oven for 6 months and tonight the glass shattered (after the loud bang). The kids were frightened and I dunno what has caused it. I also have had problems with my dishwasher and fridge also from smeg therefore can only assume this is a rubbish make.
    What did Smeg say about your glass breaking? I will have to phone them in the morning but I am still traumatised by it
  • Anonymous Mar 13, 2014
    My smeg ovens glass shattered when we took it out of the box
Go to a supermarket a buy a thermometer that is oven safe.put the thermometer in the oven and set it to 350 degrees.when the oven light goes out open the door and see what the temp reads on the themometer.it could me the tstat,are you getting the correct voltage to the element or not sure?
Posted on Aug 14, 2007
Hi - I have tried to clean the internal glass panel of our Smeg cooker using an oven cleaner.
The brown stains are on the inner surfaces of the "sealed" glass panel.
Jan 08, 2018 | Smeg Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
SMEG F170-6 Inner Door Glass
no this glass is heat toughend throug out
Feb 17, 2010 | Kitchen Ranges
I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Door Glass
The only solution seems to be ordering a custom glass piece matching the dimension of the glass on the oven door. However, since my oven is white I would like the door to be white too. Although I have found glass guys who can tint the glass door dark, I have not found anyone who can color it white. Let me know if anyone knows such a glass vendor.
Mar 14, 2008 | Amana AOGD2750 Gas Double Oven
Stuck on Glass cycle!
Hi melH Sounds like the water is not heating. Will be either an open circuit thermostat, heater element, or the switch / relay that controls the element. Using an ohm meter, test the element for resistance. Check thermostats for continuity. Regards
Aug 20, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg main oven failure
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 01, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
403 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
