Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Spectra Kitchen Range
I'm having trouble finding where and how to adjust the top burners so that they burn clean. It blackens everything grates, pots and pans when being used. What do I have to do? scooterike
  • Anonymous Mar 28, 2014
    where can i adjust the air mixture? i have removed and cleaned the brass orifice and tried adjustment screw under the knob but no fix.
  • 5,911 Answers
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Posted on Aug 13, 2007
SOURCE:
SOOT BIULD UP UNDER PANS? WITH MY GE PROFILE XL44 SPECTRA GAS RANGE
Air mix of burners is wrong. Need more air vs fuel.
Should probably get a pro to adjust under warranty.
Feb 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Left rear burner won't light - can see the spark from the front burner
If you have just cleaned the top ensure everything is dry and that you have replaced all rings properly in their correct position, let me know if this helps.
Jan 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge profile range top and burner work bu the
try cleaning the ignition wire (spark) it works with ground
Nov 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
Feb 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dirty flames
You have a problem with either air supply or with the burner getting dirty.  Clean out throughly with solvent type cleaners...no abrasives.  You should only have blue flames.
Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra
If I remember correctly, you will find three TX-15 torx head screws holding each burner head to the range top which must be removed, then you can use a putty knife to push in the clips which secure the top to the oven frame. These clips are located at the front of the stove top, at the seam of the top to the range, a couple inches in from the left and right side. Then lift top up at the front.
Nov 07, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
465 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
