Question about Sony Playstation 3 (PS3) Console
Cant upgrade my ps3
Hi there been trying two upgrade my ps3 with a memory stick it just sayes no data can u help please
    Sergeant:
  • 310 Answers
I update my Playstation I update from a memory card reader and have never had a problem. Only 2 times it wasn't recognized, but that's because I wasn't doing it right. I went back to the library next night and did it again and it worked. It sounds like you did it correct if the URL was PS3/UPDATE/PS3UPDAT.PUP. I used a Sony pro duo card insert into my reader, then when I get home I pull out the card, put it in it's Standard Size Memory Stick Pro adapter and slide it into my card slot on my PS3 and it worked fine, no problems. When there was a problem, it was because I wasn't entering the folder names correctly. Just remember to use all upper case letters and do in this order PS3/UPDATE/PS3UPDAT.PUP. Make sure to save the file name in the update folder. I've never update via computer. There's not suppose to be the word folder after UPDATE or PS3UPDAT.PUP. The URL should read like this in your address bar: PS3/UPDATE/PS3UPDAT.PUP hope this helps John
Posted on Aug 16, 2007
I am trying to copy a movie (previously copied onto my ps3 via memory pen) from my ps3 to my windows 7 laptop. When i hit copy a message comes up saying "connect storage media at the save...
Hi fat_cheesy_b
When you insert your usb stick into the usb port you then go to the movie you would like to copy hit triangle copy then you need to find your usb stick in the list so you can transfer the movie to there..
So firstly you want to make sure your usb is big enough to transfer the movie on there around 2gb would be find...Then you insert your usb stick into ps3 turn your system on go to the movie you want to copy from your ps3 system hit triangle copy and your usb device should flash up on the screen for you to select...
If your usb stick isn't being displayed you need to convert it to fat file system which is easy to do you put your usb stick into your computer go to my computer right click on the usb stick and select format to fat file system that way the ps3 will recognize the device..Try this if you need more help please be sure to reply back and i will be happy t help you =) cheers nikki (Please rate my answer)
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
I am trying to use a USB stick in safe mode to update the system software on my ps3 to 3.50. im doing it this way because it will not update via internet without stopping and encountering error 80710723. i...
The fact you're using a Macintosh system should have absolutely no bearing on your memory stick displaying the data for your PS3 to see. What may be the cause, though not very likely, is the format of the memory stick itself. You must first make sure you didn't accidentally change the format from FAT32 while saving the update to the storage. Another possibility is that memory stick may not have been formatted as FAT32 to begin with, which isn't very likely.
Check this first before continuing on. Once this part is settled, or if there are no changes necessary, proceed to the next section.
The next thing you must do is properly and immediately back up your game and save data before applying the update just in case something goes wrong. Once you've completed this part DO NOT enter safe mode again, instead, allow your PS3 to start normally and load all settings and data before proceeding to the next step.
From this point go to Settings > System Update > Update via Storage Media. Press X on the next screen when the system "sees" the data, accept the User Agreement, then start the system update.
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
I downloaded a game on to my ps3 and cant put it on my psp it is saying i need to upgrade my psp but dont now how to please help
To update your PSP turn it on,go all the way to "settings and go all the way to the top. Go to network update and connect to a wifi connection. It will connect and download the update to your memory stick. It should auto instal but if it does not go to game and memory stick and update it there.
Let me know if you have any trouble
Sep 20, 2010 | Sony PlayStation Portable (PSP) Console
My ps3 won't play blue ray movies!
Cause
PS3 has a AACS (Advanced Access Control System) is a copyright-protection technology that is used on Blu-ray Discs. The copyrighted content is protected by setting an encryption key on both the disc and the device used to play the disc.
An AACS encryption key expires in 12 to 18 months and must be renewed, so no matter if you have a new PS3 or using it already make sure you keep upgrading your PS3 firmware regularly.
Solution
There are two ways to update as listed below:
* Update via Internet
* Update via Storage Media
Download the update data directly to the system from the Internet. The latest update is automatically downloaded.
Select Settings -> System Update, Download the latest update data from the Internet. Follow the on-screen instructions to complete the operation.
You also perform this system update via a storage media, Use update data saved on a disc, Memory Stick™ or other media. Download the update data from a Web site using a PC
Hope this helps, Wishing you happy holidays and happy Gaming
Regards
KreativeGeek
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Can't restore data after linux install
In my case the problem was that the USB device did not re-mount after the PS3 restarted. Try this:
Start the backup restore process.
Remove the USB device sometime after the PS3 starts formatting
Once the PS3 has restarted, re-attach the USB device.
Wait for a while to allow the device to mount (about 15-30 seconds) before pressing the PS button to continue!
Apr 14, 2009 | Sony Playstation 3 (PS3) Console
How do I take saved data from 1 ps3 to the next
on the memory stick you need to make files, starting with PS3, then the name of where the file is on the PS3 consoll e.g game data should have GAME DATA
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 says not enough memory
you need 2 delete data or get a memory stick
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
The backup utility does not seem to work properly. I have a 40Gig drive and the backup function works as normal, but when I go to restore it says no backup data. I checked on my PC and there are five files...
Try starting the backup restore process, removing the USB device sometime after the PS3 starts formatting, then re-attaching it once the PS3 finishes restarting. Wait for a while to allow the device to mount before you press the PS button.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
Mar 14, 2008 | Cameras
Cant upgrade my ps3
maybe you didnt download the update data to the memory stick, maybe you downloaded it to your pc. Next time download the update data to the memory stick and not the pc.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
163 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
