Question about Swift Telemaster 841 (15-60x60 mm)
SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
CAN NOT USE SCOPE DUE TO WHITE METAL MOUNTING BASE DETERIORATING. WHERE CAN I OBTAIN A NEW BASE?
  • 1 more comment
  • REMBO1 Aug 16, 2007
    THE NUMBER Y0U GAVE FOR SWIFT IS FOR THE MICROSCOPE DIVISION. THE CORRECT NUMBER FOR OBTAINING PARTS FOR TELESCOPES OR SPOTTING SCOPES IS 713-529-3551 - TAKES YOU DIRECTLY TO A COMPANY THAT SUPPLIES SWIFT PARTS. I'M WAITING FOR AN ANSWER FROM THEM CONCERNING THE MOUNT, BUT IF THEY CAN'T HELP I'LL TRY THE JB WELD UNTIL I CAN FIND A MOUNT. THANKS
  • NZ Nymph Apr 12, 2008
    I am in New Zealand and have been fortunate enuff to find a swift mark II for ten dollars at a local garage sale but I need a stand is there any where in New Zealand that I could get parts from??
  • Anonymous Apr 01, 2014
    The mounting ring for the eyepiece is lose and I can't screw in the eyepiece. How can I secure the mounting ring which is rattling around inside the case in order to be able to thread in the eyepiece?
    President:
  • 1,114 Answers
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
  • Greg Cann
    Greg Cann Aug 15, 2007
    Please provide some feedback so I can help you solve the problem.
    Best regards,
    Informatica.
  • Greg Cann
    Greg Cann Aug 16, 2007
    You could always try & repair it. I have successfully repaired many metal objects using a product called JB Weld (link below).
    It is a metal loaded epoxy that when set can be filed,drilled & even tapped just like metal.
    http://jbweld.net/products/jbweld.php
I have a swift astronomical telescope model no. 859 (no D). I need an owners manual and information on how to order parts. Mark J. Lanza
This is a 6 inch Dobsonian mounted reflector. They are VERY simple to assemble-- only two parts-- the base and the tube. The small finder scope goes on top. The eyepiece goes into the focuser. That's it.
No manuals exist for that brand but all of them assemble and are used in the same fashion. Here is a manual for an Orion brand Dobsonian just like your scope.
http://content.telescope.com/rsc/img/catalog/product/instructions/IN_165D_web_XT6-8-10.pdf
Dec 21, 2010 | Swift 859D (300 x 152mm) Telescope
I have a Swift short tube catadioptic equitorial reflector telescope Model # 856. It hasn't been usable since it was moved to a new location. It may be the mirror, I don't know. Who repairs these...
This is a small reflector style telescope on an EQ mount.
1. The mount must be polar aligned to Polaris
2. The scope may need to be collimated
Read my Equatorial mount TIP on my profile page that explains how to polar align.
and watch this video that explains collimation:
http://www.andysshotglass.com/Collimating.html
Mar 13, 2010 | Swift Optics
Need 80mm eyecepie,for swift spotting scope #821.
LARGEST EYEPIECE MAGNIFICATION LENS FOR THE SWIFT 821 IS 60MM. THEY DO NOT MAKE AN 80MM FOR THIS MODEL. THE EYEPIECES ARE INTERCHANGABLE IN 15X, 20X, 30X, 40X, AND LASTLY 60X.
Sep 07, 2009 | Swift Optics
How does the front base turn on leupold std remington 541
Are you trying to get the front ring to attach to the front base? If so... clamp the ring onto a 1"dia. x ~12" long wooden dowel. Set the ring into the base from the side of the weapon (90^ from the barrel). Making sure the ring is fully seated onto the base, turn the ring/dowel 90^ until the dowel is parallel with the barrel. The fit is quite tight between ring and base. Do not put the ring on and take it back off again as the fit will deteriorate.
* IMPORTANT * Make absolutely certain both the front and rear rings are exactly in line with each other before mounting the scope. You do not want to bend or kink the scope. There are tools you can buy, or... use a 1" dowel in each ring. Align the ends of the rods with slight turning adjustments to the front ring to get both rings pointing the same direction. The rear ring does not turn, only the front one.
Aug 11, 2009 | Leupold Standard 2pc 2-piece Rifle Scope...
What is the age of a model no821 Swift spotting telescope ?
With Swift Binoculars the serial number contains the year of manufacture eg No. 1-662 Blah blah. The first two digits after the dash being 66 indicate the year as 1966. If it doesn't have a dash such as the late model Audubon then it is the first two digits of the serial number. eg.. 0745 blah blah would indicate 2007. Try this with your scope.
Jul 01, 2009 | Optics
Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
Instruction manual for 1970's custom .22 scope with BDC
Hold the outer portion of the elevation knob and unscrew the screw on top. then pull up on the outer portion and you'll see a silver screw marked with an arrow and the word "Up". Sight the rifle at a known distance and then line up the knob with that distance as you push it down on the scope and replace the screw. I have one of these and figured this out on my own, however I'm missing the mount and would like some pictures and dimensions of the mount if any of you can get some. I'm gonna be machining a new one and would like to keep it as close to the original as possible.
Sep 08, 2008 | Optics
Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Mar 02, 2008 | Optics
Swift Telemaster 841 (15-60x60 mm) Logo
2,431 people viewed this question
Top Swift Optics Experts
Lawrence Oravetz
micky dee
ray gallant
Are you a Swift Optic Expert? Answer questions, earn points and help others
