Question about Intel Motherboard
Boot up problem with Versa P600
When I start up the system it tries to networkboot (4th in the boot up sequence). Using F2 for system utilities shows that the system doesn't think that it has a Primary master drive. Persevering with multiple starts, the system then boots up and works flawlessly until I shut down, pack it away and then bring it out the next time when the problem recurrs. Once running the system correctly identifies the hard drive.
    President:
  • 2,961 Answers
When you get into utilities in F2 command, the hard drive should be able to be shown by highlighting the first boot device line and then pressing the up or down key, or the + or -keys or pageup/page down key,to change the selection it will be there it is just not selected.
Posted on Aug 13, 2007
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Jun 12, 2010 | Symantec Norton Ghost 14.0: Windows
Need to reconfigure start up on IBM computer. Windows xp at present, want to put Ubuntu on instead. When I press F8, I get safe mode options etc. Need to get to page before this, re: make cd drive the...
to make cd/dvd drive the primary one..all u gotta do is to configure the bios(press DEL/F1/F2/F10 briskly, as applicable while at the system boot, this'll enter u in the CMOS utility, search for boot Device Priority)..make cd/dvd drive the primary or 1st boot device n 2nd device @ HDD 0..
download n install any boot manager (various are available)..eg. Power quest Boot Magic..it'll b quite useful when u wanna selective startup using Multiple OS like win xp pro sp2+ubuntu..
the best is to install ubuntu first in raw/undefined hdd space next go for xp..
always better to seek professional supervision of ur System admin/vendor....
Nov 04, 2009 | IBM NetVista PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
My nec versa 2635cd wont boot from cd
most computer boot sequence is set up in the bios, you can access the bios if you watch the computer start and press the appropriate key, some are f2 as it boots or escape.
then enter bios look for the boot ......and make the cd first boot option.
then save the bios most by pressing f10 to save it, the computer will reboot......
then say press any key to boot from cd.
hope that helps
Oct 19, 2008 | NEC Computers & Internet
Update on Boot up problem with Versa P600
I have had this problem many many times at the Lab over the years, in fact I have even owned a PC that did exactly as you describe! ... What I found out was... SOME hard Drives seem to work OK, others??? It seems to be a "Timing" issue with the Hard Disk Controller.. There is NO FIX as such.. that I have ever found, Sometimes ya can find a brand of Drive that will work with.. ALWAYS.. but for the most part.. it's either put up with it.. OR get a new motherboard/PC. I have torn my hair out more than once as I said.. But essentially it is a Motherboard fault, specifically, the Hard Drive Controller, thats is at fault..
Aug 16, 2007 | Intel Motherboard
Intel Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
