Question about HP PSC 1350 All-In-One Thermal Printer
Scanner component stopped communicating
I've been using the scanner part of the all in one extensively (to scan in over 750 photos). The scanner has been working fine. I was able to preview, adjust the photos, scan and save to the computer. Then suddenly last night I started receiving the error: The HP imaging device could not be initialized. An error has occurred communicating with the device. Make sure that the device's power cord and cable are properly attached and plugged in. Refer to HP service and support on the web for more help with this error. The scanning software might be installed improperly or their might be a device conflict. Nothing has changed on my computer - no new software or hardware has been added. I unplugged and replugged the printer in numerous times. Turned the computer off and the printer off, unplugged it and left it undone for 20 minutes. Still receive the error. The error occurs after the scan appears to be complete but before the actual save to a file occurs. The only thing I haven't done is uninstall the printer software and reinstall it. Any other ideas?
Well, reinstall the software and see if it will work.
Posted on Aug 16, 2007
SOURCE:
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Xerox documate 152 scanner - won't scan
Hello.
I am a Support Engineer with Xerox Scanners.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410bsat4ube4gblqiaaaaasuvork5cyii=.
Regards,
Xerox Scanners Support
Oct 30, 2012 | Xerox DocuMate 152 Pass-Through Scanner
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
Mar 29, 2009 | Mustek A3 USB Flatbed Scanner
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
How to get my scanner to scan only the photograph
When you scan the picture, make sure you do a preview of the scanning surface in the scanner software first, then select the region corresponding to the picture only, after that, select "scan" in the scanner software.
May 20, 2008 | HP PSC 750 All-In-One InkJet Printer
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
HP PSC 1350 All-In-One Thermal Printer Logo
361 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
