Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 Having a problem with machine not taking the fax(s) and then when it does start to go the people on the other end get the start of the fax with lines of black and then some of the fax and at the end again just lines. It is like the fax machine is not taking the sheets right away. I have checked the rollers and they seems to be fine. Just wondering you have a answer to what I can do to get this working for me. Other then this the fax machine is great. Thank you in advance. Jlynn
  • 328 Answers
Any clicking noises? Can you make a good copy? Paper seems to be dragging thru the doc feeder. Gears could be stripped, cover may not be closed tightly.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 15, 2007
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
How do I set the machine to receive automatic instead of manually
go to initial set up , receive mode, change it to fax only
May 24, 2010 | Brother IntelliFax-2820 Laser Fax
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 I keep getting a end toner life message after replacing cartridge
Make sure the machine is not in direct sunlight as the toner end sensor is photo-optic. If it's an after market toner or refill...good luck with that. Lastly remove the toner tap on top of it and shake it from side to side and reinstall. The toner may be caked up inside,
Jul 13, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
140 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
