Question about Mitsubishi WS-55809 55" Rear Projection Television
Problem with inp-dtv input
The model is a ws-55511. The inp-dtv input is the only comp input that is designed to output 1080i. However whenever you input a signal of any type you get a green picture. All other tubes are lit but they're all weak. I checked and found no bad connections. I know it's not a cable problem because the same signal will work in all other comp inputs. what is it?
    Genius:
  • 1,153 Answers
Do you have the specified cables and is your TV set to right mode?
Posted on Aug 18, 2007
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
The tv says that its outputing at standard 480i resolution. how do i set it to 1080i?
You have to use the RGB component inputs on the jack panel and make sure you set your cable box the same. If your using basic cable screwed into the antenna input jack then that's the max you'll get is 480i. You have to use the RGB input to get 1080i with that model.
Dec 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
Cant go from 480 i to 1080 any suggestions?
How do you have your Blu-Ray player hooked up?
First, you have to set your Blu-Ray player to output 1080i (the highest resolution that the Mitsubishi WS-55511 can support). Then you hook up the player via component to the DTV component input on your set (it's the only input that can handle 480i/p and 1080i).
Good luck.
Danny
Dec 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 component inputs will not work
you have to hook up the HDTV receiver to the INP (or what ever the initials are) input to get HD
Oct 18, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65711 HDTV
The Verizon installer did not set the reciever to 1080i, had to set reciever to 1080i and then push 3 buttons in order on the reciever to take me to the nonstandard menu to check a box so that all channels without 1080 would automatically fill the screen.
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
