Question about Brother GX-6750 Typewriter
Correction Tape We initially were having a problem with the typewriter getting stuck and not returning so I took it apart and cleaned it out and found a paper clip stuck in it. I put it back together and now there is no problem with it returning, however the correction tape won't correct now. Every time you go to use it, it actually darkens the letters instead of removing them. And then sometimes there is a problem with the keys themselves, they are typing the wrong letters. I think I fixed that problem but the correction problem has baffled me, so any help would be greatful. Thanks in advance.
  • 328 Answers
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 14, 2007
SOURCE:
The correction tape doesn't advance. Works for few words then just gets stuck
Remove the ribbon and correction tape, type a few words make corrections check the gear that drives the correction tape to be sure it is moving (you might mark it with a dab of white out) If it moves then your L/O tape is bad. I've found that some generic ones don't fully engage the drive gear.
DickyO
Jun 19, 2014 | IBM Q27 Lexmark 6781-025 Typewriter...
Why won't correction tape advance? Works for a few words then gets stuck.
There are 2 types of correction tapes, a sticky type and a non sticky type. The sticky type is for the IBM selectric series. If you have print wheel, you need the non sticky type. Touch the tape and see if it sticks to your finger, if it does, you have the wrong tape.
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
I have an old Royal 501Plus typewriter. Correction tape will not correct. I took typing wheel out and will not type correct letters now. Please help!
check if typing wheel is the correct one for this machine.
you have to make sure the bright side of he correction has to face you
unaasp192
Apr 01, 2010 | Royal PowerWriter Typewriter
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Random letters/correction tape
You must have damaged the Daisy Wheel when you were fitting c'tape..Fit another wheel..
Apr 10, 2007 | Brother SX-4000 Typewriter
Brother GX-6750 Typewriter Logo
185 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
