Question about Yamaha RX-V995 Receiver
Yamaha RX-V995 5.1 problem playing DVD's loudly
Every time I put in a DVD and Turn the volume up, the reciever shuts off, I can turn it right back on, and it will play for a while and shut right back off. If I play the DVD at a normal lvl it works. Can anyone help?
  • Etiwandapool Dec 10, 2007
    Same problem! Now it just clicks, but won't come on. I've checked the fuse and its okay.
  • 4 Answers
Try using the analog mine had a problem with the dac. have any questions email me at facukoff@hotmail.com
Posted on Mar 07, 2008
SOURCE:
When playing the DVD when you turn up the volume the amplifier turns off.
Amplifier and an over load issue and is shutting down to protect the circuits. Needs to be checked out by tech.
Mar 08, 2015 | Yamaha RX-V420 Receiver
Hi I'm George. my yamaha rx-v795ards after an hours playing or when a loud sound comes, it turns off. you turn it on and then goes off again
Hi George,
Here is something that you can do , or have someone to assist you.
Disconnect all speakers.
Power it On, If it turns On completely , Be glad.
Put back speaker one at a time to find the cause.
If for instance , it doesnt work ....
It may need servicing.
Let us know what you find out or post back if you feel you can DIY.
Oct 06, 2012 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
Volume to about between 40 and 28 causes receiver to turn off
It sounds like protect circuit is kicking in due to excessive current. If an OHM meter is handy, check for shorts on your speakers. If not disconnect one speaker at a time from the back of the reciever. Play unit at the volume that it fails. If it then plays fine you've isolated the bad speaker.
Aug 30, 2010 | Yamaha RX-V496 Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
Enters standby after being on for only a few seconds.
Sounds like either the volume is turned up too loud, or you have a short. Have you tried disconnecting all the speaker leads from the rear, and then powering it on? Usually if it turns on for a short time and then shuts off, it is throwing itself into protection mode.
Sep 07, 2009 | Yamaha RX-V363 Receiver
Volume keeps getting louder on the right
I solved the problem but i am not going to tell you how because you were trying to charge me money to get advise. that is bull ****!!!!!! give me a life time subscription for free and I will tell you my expert opinion
Aug 26, 2009 | Yamaha RX-V870 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V995 Receiver Logo
109 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
