Nintendo Wii Console
Problem for Nintendo Wii Console
My Wii won't play Game cube games
By Lexi123 on Aug 13, 2007
I got a Wii 2 weeks ago and it's been working fine.
When I play Wii games it works great but, when I play Game Cube games it shuts off about 5 to 10 min into the game
And then it shows a no signal up on the screen.
Please help.
At first we thought it was the disc but, I went to the store ad traded for a new one and it did the same thing.
Will I have to replace it?
Same Problem
Apr 02, 2009
-   my gamecube cds want play on my wii,it cant read dis-   Guest
Dec 25, 2008
-   when i put my gamecube game in the wii it just says trouble shooting, and it wont work. what should i do? -   Guest
Best Solution
posted on Aug 16, 2007
Very Helpful)
slyde
Rank: Wiz
Rating: 82%, 90 votes
it sounds like there is something wrong with the wii that may not be an easy fix, it could be that some games do not work well with the wii, in that case try another gc game and if it still happens that is not the issue, the no signal msg is from the tv and has nothing to do with the wii, if you are not able to play any gc games, as dumb as it sounds, call nintendos support line, its a free number or go online and they will probably tell you to call them in the end of the trouble shooting guide, they actually have amazing support for their products, I purchased a wii on ebay and thought i had a bad power supply, they sent a new one for free, wasnt the problem but still if it needs replaced they most likely will replace it and not charge you anyhting , since the issue is with the console you may incur some charge or be required to prove it was purchased new or something like that but an issue like this is not easily solved by anyone without the training to do so.
Was this helpful?
Yes
No
Solution #2
posted on Aug 23, 2007
Somewhat Helpful)
Monkeau
Rank: Guide
Rating: 87%, 10 votes
Are you using the default cable that came with the wii to connect it up to your TV. i have a smililar problem, Virtual Console games dont work on my console and i get the "no signal" message on my tv. but this was only after, i started using a madcatz component cable. before that i used the default cable and they worked fine.
Was this helpful?
Yes
No
Solution #3
posted on Apr 03, 2009
Not Rated)
sdff
Rank: Master
Rating: 78%, 24 votes
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
2001
Was this helpful?
Yes
No
Solution #4
posted on Apr 02, 2009
Not Rated)
nickopopolas
Rank: Apprentice
Rating: 75%, 2 votes
Your wii may require updates to the latest software if this dos'nt work you should try and return it to get your money back and go to a different store.
Was this helpful?
Yes
No
Solution #5
posted on Aug 18, 2007
Not Rated)
soinc_881
Rank: Master
Rating: 81%, 30 votes
it sounds like so they didnt upload the gamecube game playing software correctly. so its defective= free repair.
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I can turn on the power with the remote or at the console, but I can not turn the power off with the... (More)
Answer
Our Wii console is taking the discs but an error message is coming up saying "unable to read... (More)
Answer
The will console is pictrue is truning yellow. This happened one time before and I shut down the TV... (More)
Answer
no power to unit itself, wondering if the transformer box can go after only a few months
Answer
why does my wii blow a fuse in the plug when attaching a gamecube controller
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game Consoles Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
