Question about Samsung HCL4715W 47" Rear Projection Television
HCL4715W Green Color intermittently projecting
When TV is on, the green color sometimes isnt being projected or very lightly as there is a heavy red tint. stuff that is supposed to be normally green is very dull or gray colored. Occasionally i will see a light green flash cover the whole screen and the picture will be normal again. It is intermittent and goes from normal to green not working frequently. Lots of light green flashing. Had the convergence board replaced last year. When green is out, perfect focus does not work and unable to do any green convergence from the menu. I have tested it with my DVD player hooked up and when using that it displays the same problem. Also when i watch cable through direct tv, i see the problem. I havent got to the back yet to test the connections. I was in the back a week or so prior hooking up a Wii i just bought. I had to pull out the TV only slightly to do this. Not sure if the movement or loose cables could be doing this? I was looking at the back of the TV yesterday and noticed that when the green is apparently gone, i am unable to see the green being projected at all from the back. I can see the blue and the red projectors throwing off color, but the green projector is dead. I am not sure the technical name for the part. IT looks round as is between the blue and red. I also have come to notice that if the TV is off for a while then the green works fine for a couple hours. AFter it has been on for awhile is when the green starts flickering on and off. I have tried hitting the side and moving it around and it does seem to have no affect on having the green come back on.
  • mcmasterson Aug 16, 2007
    Also, for the last week now i have not experienced any adverse picture. The TV is working excellent now. I have watched 2 full length movies without the TV losing its green. The TV has been on for over 4+ hours at a time without any issue.
    So i am not sure if something was just loose or something is on the fritz.
    President:
  • 3,130 Answers
It sounds like the common problem with this set. It is an intermittant picture tube, or there is a loose connection on the green drive board on the green picture tube. Try lightly tapping all around on the green drive board while the set is on and see if you have any change. BUT BE VERY CAREFUL! Lots of high voltage on the board. Also use a plastic or wooden device to do the tapping. If you do great, you know you need to resolder the connections on the board or clean the CRT socket on the green drive board. If there is no change, I would bet the green CRT is on its way out. But try tapping the green drive board all over as I said before, that is a very very common fault with these types of TV sets. Good Luck
Posted on Aug 18, 2007
SOURCE:
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
The screen has a yellowish color tinting the entire surface. No blurring, just poor color. I'm thinking the 3 tubes(red, green, blue) may be toast?
Hi,thats could from your convergence color ic call stk
;you may need to replaced before looking for the tube thats may just an ajustement on tube screen control beware for high voltage
that is depend how old is the tv and the number of hour it play a day....
hope that will help
May 04, 2010 | Samsung HCL4715W 47" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Connected my monster cable component to my tv but no video worked last week tv is good could it be my playstation3 or the cable
Make sure you pluged the color coded cables up correctly, Green to green Blue to Blue and Red to Red. Sometimes in low lighting you can confuse the green cable with the Blue...
Oct 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red a green shadows on most objects!
use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Oct 11, 2008 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
132 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
